Re: adding PCV
[Re: mcat4321]
#2634627
03/19/19 10:31 PM
03/19/19 10:31 PM
Posts: 4,457 Washington
madscientist
Washington
Google ME Wagner and order an adjustable PCV valve from them. Anything else is a waste of time.
Re: adding PCV
[Re: mcat4321]
#2634635
03/19/19 10:48 PM
03/19/19 10:48 PM
Posts: 43,007 Bend,OR USA
Cab_Burge
A stock pre 1970 PCV bolt in held with a nut with the stock push on PVC style cap will work fine for your application with the existing K&N breather cap. All the stock street hemi motors that had chrome valve covers came with chrome PVC caps also
Re: adding PCV
[Re: madscientist]
#2634673
03/20/19 06:32 AM
03/20/19 06:32 AM
Posts: 284 PA
Harry's Taxi 2
PA
Google ME Wagner and order an adjustable PCV valve from them. Anything else is a waste of time. so a $5 just won't work.......why not? a little info with your statement might be helpful.
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: adding PCV
[Re: Harry's Taxi 2]
#2634680
03/20/19 07:37 AM
03/20/19 07:37 AM
Posts: 17,801 S.E. Michigan
ZIPPY
S.E. Michigan
1969 and earlier street hemi pcv is the path of least resistance. Take one breather off tbe tube, put the pcv in the tube, run the hose as desired. The valve clips into a metal cap which sits inside the tube.
Rich H.
Esse Quam Videri
Re: adding PCV
#2634765
03/20/19 11:17 AM
03/20/19 11:17 AM
madscientist
Washington
DaveR answered before I saw this, but, like everything else, the PVC system was a serious set of compromises. An adjustable PCV valve is just that. I've used them to clean up dead stock rebuilds and they are worth it every time. Unless you are so cheap it doesn't matter if you can make it better or not.
Re: adding PCV
#2634796
03/20/19 12:09 PM
03/20/19 12:09 PM
Posts: 4,205 New York
polyspheric
New York
Any cam with perhaps10° or more greater .050" duration than stock has greater exhaust contamination of the chamber at overlap, and reduced idle vacuum. The amount of air admitted by the PCV is added to the air through the carburetor(s), so it affects your idle's throttle plate position w/r/t spark advance and tip-in response The Wagner allows you to adjust these factors. One less thing to worry about? Cheap.
Boffin Emeritus
