Re: Trick Flow 240 users
[Re: OUTLAWD]
#2354982
08/16/17 05:50 PM
08/16/17 05:50 PM
Posts: 528 N.W. Indiana
DblOJoe
N.W. Indiana
Here's mine, 1970 Cuda weighs 3490 446 ci RB 10.5 compression Pump Gas Stock 440 steel crank Icon pistons and Scat Rods Victor Intake and old style 950hp (small venturi) 260ish solid flat tappet cam ootb 240"s with Smith bros push rods and Harland Sharp 1.5 Rockers 2" Hooker super comp headers and 3" exhaust with Magnaflow Mufflers 8" ATI converter Its ran a best of 10.42 @ 127 @ US 131 Lift? or its top secret? .619
[Re: Dart451]
#2355753
08/17/17 10:51 PM
08/17/17 10:51 PM
dartman366
Mt. Vernon, Ohio
What timing is everyone running, right now I'm at 34 deg I am at 34 deg myself.
[Re: DblOJoe]
#2355779
08/17/17 11:08 PM
08/17/17 11:08 PM
dartman366
Mt. Vernon, Ohio
I'm at 36 deg. Never tried anything else though. I started out conservative with 32* then bumped up to 34*, seemed to help a little but it was hotter and more humid when I bumped up than it was at lower temp and humidity, I am going to try 36 after I do some other tunin'.
[Re: relax383]
#2356277
08/18/17 10:35 PM
08/18/17 10:35 PM
dartman366
Mt. Vernon, Ohio
Sorry to go off topic but is trick flow thinking about sound a small block head as well? I personally have not heard any talk of it.
[Re: dartman366]
#2356310
08/18/17 11:59 PM
08/18/17 11:59 PM
Posts: 31,203 Oregon
AndyF
Sorry to go off topic but is trick flow thinking about sound a small block head as well? I personally have not heard any talk of it. Second hand information that I have says TF tried to do a small block Mopar head and gave up on it. I don't know any specific information but I did talk to a guy who said he knew about the head and that it the project got cancelled for some reason. Not sure if it was a technical reason or a marketing decision.
[Re: dartman366]
#2357951
08/22/17 01:32 AM
08/22/17 01:32 AM
Posts: 732 eastern,Ky
70RT Charger
eastern,Ky
68 448 RB Squared and Zero decked with CR @ 10.7:1 Custom Lightweight Race Tec Pistons, factory turned steel crank, factory LY rods with ARP rod bolts, Comp XR 286 HR Cam, Trick Flow Roller Lifters, TF 240 Heads, Mancini 1.6 Roller Rockers, Smith Bros Push Rods, Holley Street Dominator, TTI 1 7/8 Ceramic Coated Headers, 6 quart Hemi pan, 391 gears. Have not made my mind up on a Carb yet. T-56 Magnum 6-speed from SST with Hydraulic Clutch.
[Re: dartman366]
#2357968
08/22/17 02:22 AM
08/22/17 02:22 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I started the project, and funds dried up. I got all the top end, Lunati Voodoo Solid Roller cam #40230732LK. 273/279 adv. 243/249 @ 0.050" Duration, 0.578"/585" lift @ 1.5:1 ratio, 110 LSA, 106 ICL. 0.61653"/0.624" @ 1.6:1 rocker ratio. 0.016" lash. Trick Flow TFS-6161T784-C00 Heads. Had the heads checked out and flowed and they were good to bolt on out of the box and flowed almost exactly as advertised. Using the TF recommended HS 1.6:1 rocker arms. This will be on a 505" stroked 440, with the 27cc dished pistons (around 10:1 compression.) I figure this should be close to 600 HP? Using the Holley Street Dominator for hood clearance, so it might cost some power? and also using the FI Tech Go EFI 8 Power Adder Plus 1200 Fuel Injection. I don't think the 215 wide BFG street tires will last too long
[Re: 451Mopar]
#2358018
08/22/17 10:11 AM
08/22/17 10:11 AM
Posts: 4,806 Wichita
GY3
Wichita
I started the project, and funds dried up. I got all the top end, Lunati Voodoo Solid Roller cam #40230732LK. 273/279 adv. 243/249 @ 0.050" Duration, 0.578"/585" lift @ 1.5:1 ratio, 110 LSA, 106 ICL. 0.61653"/0.624" @ 1.6:1 rocker ratio. 0.016" lash. Trick Flow TFS-6161T784-C00 Heads. Had the heads checked out and flowed and they were good to bolt on out of the box and flowed almost exactly as advertised. Using the TF recommended HS 1.6:1 rocker arms. This will be on a 505" stroked 440, with the 27cc dished pistons (around 10:1 compression.) I figure this should be close to 600 HP? Using the Holley Street Dominator for hood clearance, so it might cost some power? and also using the FI Tech Go EFI 8 Power Adder Plus 1200 Fuel Injection. I don't think the 215 wide BFG street tires will last too long Even 275 drag radials have problems with this type of combo on the street. Brutal torque!
'63 Dodge 330
11.19 @ 121 mph Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs.
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
[Re: carter]
#2361156
08/28/17 02:17 PM
08/28/17 02:17 PM
Posts: 92 sweden
carter
sweden
512ci sitting in a bone stock E-body, 3860 with driver. This is my weekend cruiser that see a track once or twice a year. Beting on it for two summers since I built it, old school and simpel.
4.25 x 4.375. B-block TF 240 OOTB. 802-COO 10.4:1 Holley 850 DP (4781) Holley SD intake with 1" open spacer MP .528 with 1.6 rockers 6 Quarter "Hemi pan" MP Dist 18°/36° Carter mech fuel pump with 3/8" original fuel line TTI 1 7/8 headers with full 3" exhaust
T/A 10" converter flash 4400 rpm
Rear 3.91 and 9x28 slicks
Engine has plenty of vacuum for my factory PDB and sound "stock". Best ET so far is 7.29 x 94 MPH. I hope for one more day at the track so I can do some more adjustments before I change camshaft. I had the opportunity to take my car to the track this saturday. Last time I was at the track I remember to check out my A/F gauge the last pass and It was lean on WOT. Now I made tree passes and every time I put in bigger jets and it responded with higher Mph. New best is 7.19@95.61
[Re: dartman366]
#2361517
08/29/17 01:40 AM
08/29/17 01:40 AM
Posts: 559 Idaho
LaRoy Engines
Idaho
They seem to be okay. The owner has never even driven the car yet, but, .030" over 440, 3.75 stock stroke. 9.9:1 compression, six pack, 590 HP and 574 lb-ft all before 6,000 rpm. 574 lb-ft @ 3,500 rpm and 502 lb-ft @ 6,100 rpm. I think it will move the Road Runner if he ever starts and goes someplace with it. Busy making it pretty.
[Re: dartman366]
#2361523
08/29/17 01:58 AM
08/29/17 01:58 AM
Posts: 14,539 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
It would be interesting to see a set of 240's used on a high cr stock stroke race type build with a high rpm intake manifold to see where the peaks occur.
[Re: fast68plymouth]
#2361686
08/29/17 01:30 PM
08/29/17 01:30 PM
BradH
It would be interesting to see a set of 240's used on a high cr stock stroke race type build with a high rpm intake manifold to see where the peaks occur. Based on the TF 240 CSA measurements that were posted HERE, I'd say it's going to be RPM-limited comparable to a non-MW Stage VI port. Where did you see the peaks for the bracket Stage VI combos you built in the past? I know my "less serious" stock-stroke build was 6300-6400 for HP and 5000-5200 for torque.
#2361689
08/29/17 01:34 PM
08/29/17 01:34 PM
Thumperdart
State of confusion
It would be interesting to see a set of 240's used on a high cr stock stroke race type build with a high rpm intake manifold to see where the peaks occur. On the dyno my 470 was still pulling and making power at 7000 w/the standard port window RPM's w/around 228 cc intakes and I too am curious about where they would peak w/a fairly stout solid roller...........
[Re: dartman366]
#2361698
08/29/17 01:47 PM
08/29/17 01:47 PM
fast68plymouth
So. Burlington, Vt.
I built a 13:1 rb451 with 300cfm rpm heads that made peak tq at 5800, peak hp at 7000...... Be curious to see how similarly built motor using the 240's would turn out.
