1998 Ram braking issue #263344
03/23/09 02:12 PM
03/23/09 02:12 PM
Madrid, IA
hellrzr Offline OP
hellrzr  Offline OP
Madrid, IA
My 1998 Ram 4x4 pulls hard to the left while braking. Something also feels kind of "clunky" in the front end. I don't see anything lose or bent thought. I thought it was a caliper sticking so I put on new calipers and pads. It stops better but still pulls. I'm not sure if being out of alignment can cause this or not? Going down the road at actaully drifts towards the right so it needs aligned but I'm thinking this braking issue is more than that. I've had cars way out of alignment and they've never pulled while braking. If anyone has any ideas on what to check I would appreciate it. When I can get some time off work I plan to have it aligned but that might be 2-4 weeks yet.
Thanks,
Re: 1998 Ram braking issue [Re: hellrzr] #263345
03/23/09 02:23 PM
03/23/09 02:23 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
Check the bearing hubs, they can cause braking issues and cause a clunk.
Re: 1998 Ram braking issue [Re: GTXKen] #263346
03/23/09 02:45 PM
03/23/09 02:45 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
yes and once the bearing breaks you have about 70 miles till you will be calling for the HOOK ... DAMHIK
Re: 1998 Ram braking issue [Re: JohnRR] #263347
03/23/09 04:46 PM
03/23/09 04:46 PM
Madrid, IA
hellrzr Offline OP
hellrzr  Offline OP
Madrid, IA
Thanks guys. How do you check the bearing hubs? When I did the brake job I grabbed the wheel and moved it around to see if it felt lose but it was fine. The truck does have 130k+ miles on it by the way.
Re: 1998 Ram braking issue [Re: hellrzr] #263348
03/23/09 07:39 PM
03/23/09 07:39 PM
Piqua, Ohio
dodgeram440 Offline
Happy Birthday dodgeram440  Offline
Piqua, Ohio
You replaced the calipers, now replace the hoses. One side has a restriction and isn't allowing full brake pressure to get to the caliper. The clunk could be a dozen different things. Hard to tell without actually checking it out.
Re: 1998 Ram braking issue [Re: dodgeram440] #263349
03/24/09 02:03 PM
03/24/09 02:03 PM
Madrid, IA
hellrzr Offline OP
hellrzr  Offline OP
Madrid, IA
That is an interesting idea. When we went to bleed it the passenger side appeared to have no flow. We did the driver side and after it was done then the driver side had flow. We then went and did the driver side again. I figured the fluid just took longer to get there because it had drained out but maybe there is a block. Thanks, I might try that.
Re: 1998 Ram braking issue - Fixed! [Re: hellrzr] #263350
04/01/09 01:50 PM
04/01/09 01:50 PM
Madrid, IA
hellrzr Offline OP
hellrzr  Offline OP
Madrid, IA
I finally got the brakes fixed last night. I was indeed the rubber brake hose. It wasn't allowing the fluid out fast enough and causing the brakes to stick. Thanks for the help guys!
Re: 1998 Ram braking issue [Re: dodgeram440] #263351
04/01/09 02:40 PM
04/01/09 02:40 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
They actually had problems with the calipers and hoses on the 97-98 Rams.
Back then I had a 97 Ram 4wd that chewed up the L/F pads (only the L/F) at 10K miles.
One of the hoses would collapse internally. It was a known problem and the only correct fix was to replace both front calipers and hoses. Replacing one would cause a steering pull because of the drag difference.
