Howe Racing upper ball joint 22320 maintenance #2631096
03/10/19 02:06 PM
03/10/19 02:06 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
We use only the very best speed parts on our builds and no one makes better ball joints than Howe Racing. We service the `Cuda's first set of upper ball joints with some Schaeffer's 238 Ultra Supreme heavy duty grease so they are ready to swap out the current second set at a moments notice. We have a third brand new set for the 73 Challenger build.
Forgot to mention to lube the threads on the cap and housing! Had to go back later and fix that haha!
Watch the full video on our YouTube channel
Enjoy!
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Howe Racing upper ball joint 22320 maintenance [Re: RylisPro] #2633247
03/16/19 09:46 AM
03/16/19 09:46 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
do you use these with the hotchkis upper A-arms? great vid btw!
Re: Howe Racing upper ball joint 22320 maintenance [Re: dangina] #2633337
03/16/19 12:49 PM
03/16/19 12:49 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Just screw them in.
These Howe ball joints take maintenance. We run them in the circle track cars I used to help with. The lash is set with a 1/2” male socket head from a ratchet, extension, etc. That screwing motion tightens the cup against the ball of the stud. Then there is a set screw to keep the cup from unscrewing itself.
I’d catch them loose every few races. About 100 laps with practice, qualifying, race per race weekend.
Take a paint marker and draw a line across parting line of the cup and body.
These are not an install and forget it part like stock ball joint. Check every 5000 miles, every oil change...
Re: Howe Racing upper ball joint 22320 maintenance [Re: dangina] #2633425
03/16/19 05:49 PM
03/16/19 05:49 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
Yes we use these with the Hotchkis arms but I wasn't able to take the Proforged ball joints off by hand as they are to torqued down to 100 ft lbs. We'll mount the Hotchkis arms on the 73 Challenger and replace the ball joints with the Howe pieces.
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Howe Racing upper ball joint 22320 maintenance [Re: RylisPro] #2633556
03/17/19 09:47 AM
03/17/19 09:47 AM
Rescue CA.
joes68340s Offline
joes68340s  Offline
Rescue CA.
Do you run a grease seal with those ball joints.
Re: Howe Racing upper ball joint 22320 maintenance [Re: joes68340s] #2633587
03/17/19 10:46 AM
03/17/19 10:46 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
If you look at the instructions from Howe they do offer a boot so that is an option.
Instruction PDF
Don't be the exception.
Re: Howe Racing upper ball joint 22320 maintenance [Re: Supercuda] #2633614
03/17/19 11:50 AM
03/17/19 11:50 AM
Rescue CA.
joes68340s Offline
joes68340s  Offline
Rescue CA.
Re: Howe Racing upper ball joint 22320 maintenance [Re: joes68340s] #2633660
03/17/19 01:01 PM
03/17/19 01:01 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
We don't like the 22399 boot from Howe because it does not have a metal ring embedded inside it. The rubber boots that come in Moog lower ball joints are the boots that we prefer to use as they keep dirt out and seal better.
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Howe Racing upper ball joint 22320 maintenance [Re: RylisPro] #2633708
03/17/19 02:09 PM
03/17/19 02:09 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Moog doesn't appear to sell the boot separate, though they direct you to https://www.suspension.com/universal-dust-boots.asp for boots.
Down in the question section a question about getting a boot seperately is asked.
https://www.moog-suspension-parts.com/moog-k772
Do you have a source other than buying a ball joint?
thanks
Re: Howe Racing upper ball joint 22320 maintenance [Re: Supercuda] #2633724
03/17/19 02:38 PM
03/17/19 02:38 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
The ball joint here looks like it would probably work?
(WARNING! I have not used this exact dust boot before! So I am NOT 100% sure!)
It has the metal ring that seals the ball joint much better
https://www.speedwaymotors.com/Repl...t-Dust-Boot-K772-Application,100099.html
At $1.99 each its worth a shot!
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Howe Racing upper ball joint 22320 maintenance [Re: RylisPro] #2633748
03/17/19 03:47 PM
03/17/19 03:47 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You rock
