Re: Trick Flow sb heads
[Re: ZIPPY]
#2646115
04/17/19 04:33 PM
04/17/19 04:33 PM
Posts: 339 Gilroy,CA.
mopardude318
Gilroy,CA.
I’m gonna order a set for a solid roller build I’m workin on. I’m only at 10:1 though. Don’t wanna go more than that really. More street than strip.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
[Re: scottb]
#2646243
04/17/19 09:53 PM
04/17/19 09:53 PM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
I just don't get it. 191cc, why? Basically where all these stock config heads are coming in at, and it's just not enough.
The Air Wolf 220's have enough volume to support 600+ horse without big compression and without a big roller cam. He's been out of business for years and no one has duplicated the effort...WTH?
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: MoparBilly]
#2646245
04/17/19 09:59 PM
04/17/19 09:59 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Anyone that has talked to the TrickFlow guys will know they aren’t idiots. 80% or more of the Mopar guys building small blocks will be happy with these. I’m just hoping they offer a better head in the near future
[Re: MoparBilly]
#2646340
04/18/19 07:11 AM
04/18/19 07:11 AM
Posts: 11,730 Portage,michigan
B3422W5
Portage,michigan
The Air Wolf 220's have enough volume to support 600+ horse without big compression and without a big roller cam. He's been out of business for years and no one has duplicated the effort...WTH? I talked to Dwayne about these heads couple weeks ago. He said a well done, zero deck flattop piston stroker with a good flat tappet cam will make 600 falling off a log with these heads if they are any good. And initial reports sound like they definately are good I have no idea what else somebody could want out of a direct bolt on factory replacement head. 90% of small block guys would consider that stout. That is the class Trick flow is teaching to The more exotic offset stuff most tight wallet Mopar guys are just are not going to buy in any numbers to make such a product viable. These heads should get a typical bracket A body car in the 9’s without anything exotic. That accounts for most all of the market
[Re: B3422W5]
#2646817
04/19/19 12:16 PM
04/19/19 12:16 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Not to draw away from original poster's intentions, but... what I'd like to see is comparisons between Eddy vs Trick Flow. I'm building a 410 with CR about 9.5-10 (Hughes kit, engine partially built)... camshaft (flat hyd) still to be determined ...wanting wide range rpms especially strong mid-range and ability to run strong higher rpms (I do pylon AX, HSAX and road course lapping sessions).
My purchase is on-hold until ~mid-summer or end of this summer, maybe into early 2020... maybe the EDDYs are simply established and proven.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Mopar Mitch]
#2646878
04/19/19 03:35 PM
04/19/19 03:35 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
My purchase is on-hold until ~mid-summer or end of this summer, maybe into early 2020... maybe the EDDYs are simply established and proven. M Edelbrock heads and TrickFlow heads shouldn’t even be mentioned in the same sentence. Edelbrock heads are poor quality and max out at 243 cfm. TrickFlow heads are nicely set up with several options, cnc ported and flow over 300 cfm with several options offered
[Re: Duster3406pck]
#2647882
04/22/19 04:47 PM
04/22/19 04:47 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
UPS just left a box from Summit....weights 61 lbs....
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: RapidusMaximus]
#2648008
04/22/19 10:59 PM
04/22/19 10:59 PM
70AARcuda
las vegas
Took them out of the box....photos thats all
Tony
[Re: 70AARcuda]
#2648317
04/23/19 11:31 PM
04/23/19 11:31 PM
Posts: 3,518 pacific northwest
Stroker Scamp
pacific northwest
Are you going to get them flowed or just bolt and go?
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
[Re: Mopar Mitch]
#2663323
06/07/19 01:27 AM
06/07/19 01:27 AM
Posts: 31,091 Oregon
AndyF
My purchase is on-hold until ~mid-summer or end of this summer, maybe into early 2020... maybe the EDDYs are simply established and proven. Interesting question but it will take a while before anyone does that sort of test. You probably need to talk to Hughes Engines or maybe Brian at IMM to get some A to B comparisons. Not sure how many folks even have the SB Trick Flow heads on the dyno yet. The engine we ran today is the first set that I've seen.
[Re: AndyF]
#2663357
06/07/19 07:02 AM
06/07/19 07:02 AM
Posts: 2,412 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
We ran a 408 on the dyno today with a set of the Trick Flow heads. Engine had a Performer RPM intake, Holley Sniper setup and a 230/236 hyd roller cam. It made 450 hp and 490 torque. Not bad numbers for sweet street engine. It idled super smooth with a ton of vacuum and was a very quiet and smooth engine. Should make a great cruiser for the guy. This is the first set of these heads that I'd seen. They look like they'll make a bunch of power but this was a street engine rather than a race engine. Anybody else have some numbers to share yet? Morning Andy, was this an LA or Magnum engine and what was the rpm operating range, thanks!
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
[Re: fast68plymouth]
#2663676
06/08/19 12:45 AM
06/08/19 12:45 AM
AndyF
What size are the headers? I think those are 1 3/4 Schoenfeld sprint car headers but I bought them a long time ago so I'm not positive.
