Np203 to np241 direct swap? #2631835
03/12/19 11:44 AM
03/12/19 11:44 AM
junction city oregon
V
viperblue72 Offline OP
V
I have a married 727/203 in my ramcharger and have a 89’ parts truck with 727/np241.
Will this 241 directly swap with my 203? Also are the driveshaft lengths similar?
I am in the process of installing a 500hp 440/727 swap.
Re: Np203 to np241 direct swap? [Re: viperblue72] #2631867
03/12/19 12:33 PM
03/12/19 12:33 PM
enfield, CT
ViperDave Offline
ViperDave  Offline
enfield, CT
output shaft length is difference on the trans. your current output shaft is too short
The adapter is different between a 203 and 241. But the 241 adapter you have on the 727/241 would work.
But that doesn't help the output shaft issue
67 Dart GT Vert 273/904
72 Town & Country 440/727
90 D350 reg cab dually cummins
15 Scat Pack Challenger
Re: Np203 to np241 direct swap? [Re: ViperDave] #2632113
03/13/19 12:15 AM
03/13/19 12:15 AM
Las Vegas, NV
chargerbr549 Offline
Las Vegas, NV
You would have to take the output shaft in the 89 smallblock trans 727 and install it in your big block 727 case and put the 241 adapter housing on it thats what I did on my 77 Ramcharger with a factory 440/727/203 setup that I converted to a 1984 727/241 part time transfer case setup and I had to change driveshaft lengths at least on the rear.
An issue you might run into is when swapping the output shaft you need to make sure the year big block trans is I believe 1976 and newer (I thought I read somewhere the years were 76-93 had the same spline angle) since they changed the angle of the spines on the output shaft and if you mismatch the parts its a good chance they could strip out.
