Anyone done a 4.25 crank in a 5.7 stroker? #2631526
03/11/19 06:34 PM
03/11/19 06:34 PM
Between a rock & a hard place
cudadoug Offline OP
cudadoug  Offline OP
I see that K1 tech has a 4.25 stroke G3 crank. I also see several rods with the corresponding 2.00 rod journal...
What I don't see is a shelf piston to make it all work. I admit that I only spent about 15 minutes on google, but I did hit ICON, CP, Diamond and the longest stroke application was 4.05.
Anyone know something that I don't? Custom piston needed. perhaps?
Think it will clear or will the block need a notching? If the block does need clearanced, is that safe with a 5.7 block?
Discuss...
Re: Anyone done a 4.25 crank in a 5.7 stroker? [Re: cudadoug] #2631701
03/12/19 08:09 AM
03/12/19 08:09 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
I'll get back to this later , you can use 1.09 ph pistons with 6 in rods, but the throws have to be trimmed. but for the most part pistons are custom ordered, CP and , Dimond both have "programs" for 1.02/1.03 PH pistons. 6.1 C to C rod works best., next option is Nissan's 6.077
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: Anyone done a 4.25 crank in a 5.7 stroker? [Re: cudadoug] #2631925
03/12/19 02:56 PM
03/12/19 02:56 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Discuss...
4.05+ stroke have clearance issues , mostly the last oil drain back on the passenger side of the block, the passage that connects the last 2 drain backs together there is just enough thickness for the notch that is needed for the 4.05 crank the 4.08 gets hairy and 4.20-4.30 there is not enough casting to notch it and not break thru to the passage ,
3, options here, 1st is to block the last drain back at the head, 2nd is to tap off the last one on the outside of the block and route to the oil pan and plug the drain back internally , 3rd is the best solution(in my opinion) is to clearance the passage then tube the passage and dimple it......not to forget the windage tray it also needs some attention for the 4.05+ cranks.
CP has a 4.20 inch crank, less issues......Now if your real adventurous, offset the 4.25 to 4.3 with 1.88 Journal ......... it's like trying to fit 64 Imperial into a 1 car garage.
The 9.25 deck height of the 5.7/6.1s make the 4.20+ cranks a challenge the 9.28 Deck height of the BGE(SRT392) gives you better option.
Re: Anyone done a 4.25 crank in a 5.7 stroker? [Re: ric3xrt] #2632156
03/13/19 07:32 AM
03/13/19 07:32 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
also keep in mind you can use cometic MLS Head gasket C5876-120 , it's a 4.1 bore .120 thick gasket...yes .120 thick gasket, again this type build is those who think outside of the box and are not looking for 100 runs+ type build. .
look at it this way. Deck Height typical 5.7 is 9.25, add the .120 gasket you have 9.37 "useable DH" . pull off .003 for decking and then .048 for Piston to Head clearance another .006 for rotating assembly oil clearance leaves you 9.313 , 2.125 crank throw +6.125 C to C rod and you have a 1.06 pin height piston.....it's been done both Arrington(before being sold), and Muscle Motors extreme have done it also...not for the faint of heart.
A BGE/SRT392 block with .120 gasket is 9.4 , 4.09 bore with a offset grind 4.3 crank yields 451 CI...keep compression in the mid 10's and the gasket won't blow.....needs to be well tuned also
Custom order Cometic Gasket with a 4.155 bore and .110 thickness you can go 4.125 bore on the BGE block and the 4.3 crank....459(460) ci inches of.. iron block fun.
Re: Anyone done a 4.25 crank in a 5.7 stroker? [Re: ric3xrt] #2632311
03/13/19 02:53 PM
03/13/19 02:53 PM
cudadoug Offline OP
cudadoug  Offline OP
Wow! Alas, not as easy as I thought. I noticed that upon mock up, my 4.05 crank was tight so this doesn't surprise me.
Humbled, I might save a 4.25 version for my second build and stay "in the box" for this one.
THANK YOU, sir!
Re: Anyone done a 4.25 crank in a 5.7 stroker? [Re: cudadoug] #2632610
03/14/19 12:02 PM
03/14/19 12:02 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
I'm gearing up to do some Videos on these G3's Going over the oiling system, some of the different heads I have dissected and few builds one of the builds in the works this year is a 444 CI 6.bassed 4.08X4.25.
Re: Anyone done a 4.25 crank in a 5.7 stroker? [Re: ric3xrt] #2947459
07/26/21 05:48 PM
07/26/21 05:48 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Did you ever make these oiling vids?
Re: Anyone done a 4.25 crank in a 5.7 stroker? [Re: ric3xrt] #2948271
07/28/21 07:14 PM
07/28/21 07:14 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
I just came across this- I would also love to see these videos. Good info posted though!
Re: Anyone done a 4.25 crank in a 5.7 stroker? [Re: HotRodDave] #2996328
12/18/21 07:15 AM
12/18/21 07:15 AM
Springtown Pa
Ray408G3Hemi Offline
Springtown Pa
Videos stopped when his health issue started, I was over there the other day picking up my 488ciG3, he's been real low key , has a pair of AFR heads and a new Dart block........cut in to pieces , guy can't leave anything in one piece .
https://www.youtube.com/watch?v=Gl5a5kY1D0c
1963 Thunderbolt 496FE 10.80 (still a work in progress)
1968 Mustang slow a$$ 428 FE
1971 Boss 351 Mustang 11.20@115mph
1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA
1996 Viper GTS
2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor
2009 Ram 9.65@144MPH 463CI G3 NA
2010 Challenger 9.91 @ 139MPH 408CI G3ci NA
2019 F150 (local dealer's Lightning package) ..11.90s
Re: Anyone done a 4.25 crank in a 5.7 stroker? [Re: Ray408G3Hemi] #2996981
12/20/21 10:27 AM
12/20/21 10:27 AM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
Just learned a lot from this guys video. Thanks!
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
