Re: proper timing for breakin (sb)
[Re: topside]
#2631307
03/11/19 02:26 AM
03/11/19 02:26 AM
Posts: 5,788 Hamilton, Ontario Canada
Magnum
Engine break in on a slider cam does not care where the timing is at. As long as it runs. With that said proper is ideal but anything between 5 to 20 during high idle will suffice.
We all know total for power but during breaking, who cares.
[Re: dvw]
#2631422
03/11/19 12:25 PM
03/11/19 12:25 PM
Posts: 25,618 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I would use as much initial timing as the starter will take, retarded timing makes the motor run hotter. Then adjust the total after breakin.
[Re: John_Kunkel]
#2631490
03/11/19 04:31 PM
03/11/19 04:31 PM
Posts: 3,535 Canuckville
68Cbarge
Canuckville
Set crank at 10 degrees BTDC with rotor pointing at #1, index the reluctor ring exactly pointing to the pickup. Fill float bowl(s) with gas Will start first click of key, Proceed with break in procedure.
'68 Newport Custom Barge on a Budget!! BOAB 1973 Satellite WAGON! 318- 3 on the tree!! 2008 Chrysler 300c HEMI!
[Re: 68Cbarge]
#2632489
03/13/19 11:56 PM
03/13/19 11:56 PM
Posts: 1,908 Nebraska
4406bbl
Nebraska
Set crank at 10 degrees BTDC with rotor pointing at #1, index the reluctor ring exactly pointing to the pickup. Fill float bowl(s) with gas Will start first click of key, Proceed with break in procedure. Do this, most important that it starts immediately, then add a little more with a light once it starts, about 35-40.
