Sideways burnout #2630376
03/08/19 01:30 PM
03/08/19 01:30 PM
Minnesota
Hemi_Joel Offline OP
Minnesota
How do you prevent going sideways when doing a burnout? It has been an issue for me. Thanks, Joel
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Sideways burnout [Re: Hemi_Joel] #2630378
03/08/19 01:32 PM
03/08/19 01:32 PM
Cab_Burge Online work
Cab_Burge  Online Work
I think you can fix that with either tire diameter, make sure both tires are within 1/4 inch circumference of each other, or in the posi unit.
Re: Sideways burnout [Re: Cab_Burge] #2630382
03/08/19 01:38 PM
03/08/19 01:38 PM
Minnesota
Minnesota
My car has a spool. I better check the tire daimeters
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Sideways burnout [Re: Hemi_Joel] #2630385
03/08/19 01:42 PM
03/08/19 01:42 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Needs more wheel speed.
69 GTX 68 Road Runner
Re: Sideways burnout [Re: JERICOGTX] #2630393
03/08/19 01:56 PM
03/08/19 01:56 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
Tire speed like said above. If the tire tries to grab hold instead of spin it will make you go sideways. I personally smack the gas hard to make sure I get my tires spinning than ease off to keep the rpms in check.
Re: Sideways burnout [Re: DusterKid] #2630409
03/08/19 02:35 PM
03/08/19 02:35 PM
Minnesota
Minnesota
How much wheel speed is required?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Sideways burnout [Re: Hemi_Joel] #2630422
03/08/19 03:23 PM
03/08/19 03:23 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Agree more wheel speed also make sure your front brakes are working evenly up
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Sideways burnout [Re: WHITEDART] #2630495
03/08/19 06:35 PM
03/08/19 06:35 PM
NE
moparpoolman Offline
NE
Make sure tire pressures are the same. 4 spd or Auto? What gear are you doing your burnout?
Re: Sideways burnout [Re: WHITEDART] #2630497
03/08/19 06:35 PM
03/08/19 06:35 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Worn track surface will do that. Wonky corner weights and different size tires will as well.
Re: Sideways burnout [Re: CMcAllister] #2630525
03/08/19 07:53 PM
03/08/19 07:53 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
More wheelspeed plain and simple..If it launches and drives straight after the launch then it clearly is not a brake, chassis or tire thing. Since you say its a burnout thing I assume only when which means you need more wheelspeed. HIgh gear and how much depends on the car but enough for it to go straight is the answer
Re: Sideways burnout [Re: Al_Alguire] #2630530
03/08/19 08:03 PM
03/08/19 08:03 PM
Minnesota
Minnesota
It's a manual transmission car. I've been doing a burnout in second. When I have attempted it in third a couple times it has slipped the clutch or been right on the verge of slipping. I'm getting rid of the soft lock clutch. That should make 3rd gear burnouts no problem
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Sideways burnout [Re: Hemi_Joel] #2630534
03/08/19 08:20 PM
03/08/19 08:20 PM
P
Porter67 Offline
Porter67  Offline
P
What gear and what type tire?
What rpm are you holding it at during the burnout?
Re: Sideways burnout [Re: Hemi_Joel] #2630549
03/08/19 08:56 PM
03/08/19 08:56 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
As already mentioned, wheel speed. And a quick snap of the throttle. I snap the tires in 2nd and immediately go to 3rd gear. Car never moves, stays perfectly straight. And a line-lock makes the whole thing much easier and quicker.
My Duster street car had 3.23 gears and no line-lock, I only had 5 passes on the car before selling it last Fall but that combo was causing me to go a little sideways also, I had to get real aggressive with the throttle to make it go straight. Making sure the tires are wet helps also of course.
Re: Sideways burnout [Re: ProSport] #2630559
03/08/19 09:16 PM
03/08/19 09:16 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
I've had it happen in one lane and not in the other lane.
Probably the track surface.
Re: Sideways burnout [Re: Sammy] #2630661
03/09/19 09:34 AM
03/09/19 09:34 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've had mine do it as well. My burnouts are high gear only at 6000 rpm. I would think that would be plenty of wheel speed?
Doug
Re: Sideways burnout [Re: dvw] #2630667
03/09/19 09:45 AM
03/09/19 09:45 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I had a friends car do this once, and it turned out that we had the scaling of the car screwed up. Simple fix by just adjusting the torsion bars...
I'd start by putting the car on a flat surface, and measure from the ground to the front fender lip on both sides with someone of your weight in the car. They should be very close in height, with the driver side being a TOUCH higher to help put some pre-load on the right rear.
Re: Sideways burnout [Re: dizuster] #2630687
03/09/19 10:50 AM
03/09/19 10:50 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
My car was a four speed. 3,000 rpm in 3rd, let go of clutch. Bring up to 5. Line loc on, hold steering wheel tight. I found that with the line loc engaged, I can put left to right pressure on the steering wheel to push the back of the car straight.
Re: Sideways burnout [Re: sgcuda] #2630931
03/09/19 10:24 PM
03/09/19 10:24 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
I have been able to just go up or down a bit on the torsion bar. If the rear moves right I would lower driver side, but it doesn't take much. You could split it, up half on one side down half on the other.
best of 11.39 at 117 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: Sideways burnout [Re: FurryStump] #2630936
03/09/19 10:40 PM
03/09/19 10:40 PM
Minnesota
Minnesota
I press the brake pretty hard and set the line lock. Dump the clutch at 5000, try to hold it at around 5500-6000. 4.57 rear, 1.78 2nd, 1.30 3rd,
Rear tires are MT ET Street, LT 30 x 13.5-15, Bias-Ply, front are 6.70-15 bias ply. Straight front axle, wilwood discs, 4 link rear, afco coil overs on all 4 corners.
So in 2nd gear 5500 rpm is 60 mph. 3rd gear at 6000 would be 90 mph
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Sideways burnout [Re: Hemi_Joel] #2630948
03/09/19 11:38 PM
03/09/19 11:38 PM
The faster you spin the tires the sooner they will get hot enough to smoke, correct? I use to do all my burn outs in my old Hemi stick shift car in 3rd gear per some other SO CA Mopar factory back racers advice back a long time ago.
