Re: Sideways burnout
[Re: Hemi_Joel]
#2631580
03/11/19 08:41 PM
03/11/19 08:41 PM
Posts: 356 NE
moparpoolman
NE
It's a manual transmission car. I've been doing a burnout in second. When I have attempted it in third a couple times it has slipped the clutch or been right on the verge of slipping. I'm getting rid of the soft lock clutch. That should make 3rd gear burnouts no problem I do my burnout in 2nd with 4.10's and 28 inch tires, only starts to kick to the left when tires start to grab. Does your car go sideways instantly or after some smoke? maybe the tires are ready sooner than you think. Soft Lock clutches seem to be preferred among many stick car guys, Takes allot of shock out of the system, I would think twice before getting rid of it. What clutch do you plan on switching to?
[Re: Hemi_Joel]
#2631809
03/12/19 11:11 AM
03/12/19 11:11 AM
Posts: 290 Cincinnati, Ohio
d7cook
Cincinnati, Ohio
You can aggravate the car going sideways by steering into it as if you were drifting. It's a natural reaction but if its going sideways while not moving forward during the burnout try holding the wheel straight.
1967 Coronet, 1989 Daytona tube chassis.
Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT.
-Banned for life from V8Buick.com-
[Re: d7cook]
#2631866
03/12/19 12:33 PM
03/12/19 12:33 PM
Posts: 19,304 Las Vegas
Al_Alguire
Las Vegas
Since it was asked how much wheelspeed is enough, my answer would be however much it takes to straighten it up. I know manual trans cars have a bit of an issue as you have to get it rolling and not kill the clutch. FWIW my current car the burnouts are 6-6500, in high gear I use a limiter to get going at 5900, once it blips that I let it rip. In this car in high gear 6500 is probably 130+ mph. Have to look at the racepak to see where that is?
[Re: Al_Alguire]
#2632026
03/12/19 07:18 PM
03/12/19 07:18 PM
Posts: 3,097 back in Georgia
dthemi
back in Georgia
Just for sake of conversation, we all have to do what al is talking about sometimes, or cruddy burnout boxes, out of level areas, you name it. Just blip it up quick, and high. Personally, I like the car to go straight on the burnout whether I'm barley spinning, or near on fire. Spinning super fast just vulcanizes the center of the tire, and if the situation means that's all you can do, you do it. Setting the car up to go straight on the run, then adjusting the front springs till the car will burn straight no matter what RPM is a better way IMO since you can let the tire settle down and flatten out some. Just personal preference.
[Re: d7cook]
#2632263
03/13/19 12:26 PM
03/13/19 12:26 PM
Posts: 7,471 Minnesota
Hemi_Joel
Minnesota
You can aggravate the car going sideways by steering into it as if you were drifting. It's a natural reaction but if its going sideways while not moving forward during the burnout try holding the wheel straight. I never thought of that before, but it makes sense. Good info! Thanks everyone for all of the replies
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#2632398
03/13/19 07:39 PM
03/13/19 07:39 PM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
Sanoma has a well worn groov in the burnout area in the left lane. Just have to adapt😁
Founder and CEO of the Central Valley Mopar Drag Pack
