Rear Shocks #2630083
03/07/19 06:43 PM
03/07/19 06:43 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
89 Dakota 2WD 3.9. Air shocks in there now. Have a pair of SensaTrac Load Levelers with coil springs laying around. Thinking of switching out. What are you using?
Grandma always said I had "hands of gold"!
Re: Rear Shocks [Re: CHRGR69] #2630199
03/08/19 01:02 AM
03/08/19 01:02 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
How much lift do you need? Then, why do you need the lift? Tire clearance or load capacity?
I usually lower the rear ends on the Dakota chassis I use, there is usually plenty of height for anything I've needed. Gene
Re: Rear Shocks [Re: poorboy] #2630292
03/08/19 10:45 AM
03/08/19 10:45 AM
CHRGR69 Offline OP
CHRGR69  Offline OP
Not height, just better ride quality and level body.
Re: Rear Shocks [Re: CHRGR69] #2630574
03/08/19 09:51 PM
03/08/19 09:51 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I've not ever experienced a better ride with any shock that had a helper spring, they have always made the ride a bit stiffer to me. Your experience may be different then mine has been. Gene
Re: Rear Shocks [Re: poorboy] #2630576
03/08/19 09:54 PM
03/08/19 09:54 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Shocks aren't going to make it level. The higher rear end angle needs new springs to lower it the same height as the front. My Durango ,same chassis as the Dakota took 3" eibach drop coil springs to get it level. Your's uses leaf springs I think and they make a lowering kit for that also. Before .
Re: Rear Shocks [Re: stumpy] #2630579
03/08/19 09:57 PM
03/08/19 09:57 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
after.
Re: Rear Shocks [Re: stumpy] #2630669
03/09/19 09:57 AM
03/09/19 09:57 AM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
Air shocks and coil over shocks make for a lousy ride. Find yourself a good set of nitrogen or gas-charged shocks.
Change your shocks first and see how it sits before you change anything else .
