Thanks Transman, I appreciate your help.
I hope there was no offense taken by you or anyone else by me not knowing if I was explaining something that I don't fully understand
, hence the reason why I was hoping to learn more through a post here.
Much thanks again...
Can you add any insight on the differences (if any) between a case for a lock up converter vs one without lock up?
I have a choice between two complete 727 BB transmissions (1975 and 1978) to use as a core donor for a SB 727 buildup.
I currently have a later year (I think 1979) SB front case to use and I'm wanting to verify if it's from a lock up or non-lock up application. Any visual differences?
So…can a lock-up converter case be used with internals swapped over from non-lockup transmission? (and with a low band apply transbrake)
Thanks!
