Re: Roots Guys Q:
[Re: Dragula]
#2628298
03/03/19 03:49 PM
03/03/19 03:49 PM
Posts: 43,123 Bend,OR USA
Cab_Burge
Re: Roots Guys Q:
[Re: Dragula]
#2628603
03/04/19 11:03 AM
03/04/19 11:03 AM
Posts: 3,097 back in Georgia
dthemi
back in Georgia
Water/meth injection would be my choice between those options. An intercooler on a roots, in a car, is more trouble and weight than just switching fuel when you want to race. They work great on a boat where there are millions of gallons of cold water on hand, at all times lol.
Personally, E85 is kinda like a cure all ills for the street, as least from where I sit. Great cooling effect, reasonable volume to manage, available, and no where near the hassle of methanol.
Re: Roots Guys Q:
[Re: Cab_Burge]
#2628640
03/04/19 12:48 PM
03/04/19 12:48 PM
Posts: 965 Odessa, Fl
blowndart
Odessa, Fl
I've made 924 HP on CA pump swill with a 10:71 with two Carb Shop 1050 Dominator carbs at 7300 RPM with 33 degrees total timing with 7.0 lbs. boost at 130F M.I.T., we swap the pulleys and put in 114 octane race gas and lowered the timing to 25 degrees total and that motor made 1027 HP at 6500 RPM with 12.0 lbs.
Was this a hemi? All aluminum? That's pretty high compression for 91 octane even with only 7 psi.
Re: Roots Guys Q:
[Re: blowndart]
#2628770
03/04/19 05:23 PM
03/04/19 05:23 PM
Cab_Burge
It was a Hemiroid motor, early 4.190 rough bore Mopar Mega iron block with Stage V aluminum street heads. I had it bored to 4.250 due to thin(less than .300 left in the cylinders after boring) cylinder walls and added a 4.375 stroke crankshaft.
Re: Roots Guys Q:
[Re: Dragula]
#2628854
03/04/19 09:07 PM
03/04/19 09:07 PM
Posts: 4,206 New York
polyspheric
New York
My turbo car has a big FMIC + Snow methanol/water, but not tried high (30 psi) boost yet. The "sandwiched" intercooler (between the GMC base and manifold inlet) sounds good, but except for regulating the water temperature (and this is limited to radiator, ice chest) and flow (pump speed and pressure if a separate source) there isn't any adjustment built in. Whatever and wherever it flows is what it's going to be, and the core plates etc. restriction obstruction varies with their cooling value: large plates = reduced flow = lower charge temperature. More thickness (add another one?) is the only way to get the charge down more.
Again: no modern supercharger with helixed rotors (Eaton, BDS, etc.) discharges at the same flow rate all along the length of the discharge port, the flow is heavily biased toward the forward end of the window. Does the IC account for this? The flow at the back end of the rotors doesn't even go directly to the manifold, but is re-cycled up into the rotors again. Not as much help as it appears.
Boffin Emeritus
Re: Roots Guys Q:
[Re: Dragula]
#2628878
03/04/19 09:58 PM
03/04/19 09:58 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I wouldn’t put a water/air intercooler on anything other than a boat. A drag strip only car may be an exception with a centrifugal blower or turbos. A roots blower outlet just doesn’t have the square area for effective cooling and airflow. On a car, it will be inconsistent with temps until it is finally heat soaked. Once it’s heat soaked it’s useless and detrimental to power. Tuning for atmospheric conditions is bad enough without throwing in an inconsistent charge temp. Much better off using an alc based fuel to keep charge temps in check. I don’t recall ever seeing a truly fast roots/ intercooler combo. Lots of very fast roots/ alc combos though.
Re: Roots Guys Q:
[Re: Dragula]
#2629050
03/05/19 10:32 AM
03/05/19 10:32 AM
TRENDZ
Milwaukee WI
I built this intake for a friend. The water core is 8x16x3. It uses an 8 gallon liquid cell with only 3/4” lines. He uses a mix of water/ ice at the track. 12 lbs of boost in a single pass will melt almost all of the ice. Intake temps start at 60 degrees in the burnout, and are around 100 at the return road. That core has a square air flow area of 128 inches. There is no difference in pressure above or below. Turbos make much less heat than a roots. Imagine how the small roots core would need to absorb a great deal more heat with a much smaller exchanger.
Re: Roots Guys Q:
[Re: TRENDZ]
#2629078
03/05/19 11:57 AM
03/05/19 11:57 AM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
I built this intake for a friend. The water core is 8x16x3. It uses an 8 gallon liquid cell with only 3/4” lines. He uses a mix of water/ ice at the track. 12 lbs of boost in a single pass will melt almost all of the ice. Intake temps start at 60 degrees in the burnout, and are around 100 at the return road. That core has a square air flow area of 128 inches. There is no difference in pressure above or below. Turbos make much less heat than a roots. Imagine how the small roots core would need to absorb a great deal more heat with a much smaller exchanger. Thanks for the info,Your cores are the biggest that can be put under a roots that I know of and my single core is 4.5" x 13" x 3" just fyi.The core straighten the air flow into the intake and cut down on rear bias.
Re: Roots Guys Q:
[Re: TRENDZ]
#2629235
03/05/19 04:28 PM
03/05/19 04:28 PM
Cab_Burge
Talk about filling up the engine compartment Good results also
Re: Roots Guys Q:
[Re: hemi-itis]
#2629485
03/06/19 02:55 AM
03/06/19 02:55 AM
Cab_Burge
Any thing you can do to improve air flow, in or out, should improve performance, especially with a huffer!
Re: Roots Guys Q:
[Re: Dragula]
#2630369
03/08/19 01:07 PM
03/08/19 01:07 PM
Clanton
northern,Ohio,USA
If you have no issue with hood clearance, and your not running Methanol, is it better to go water injection or one of those inter coolers sandwiched in for max boost? Dragula did you want to talk about the w/meth injection?Would you make a larger intercooler if you could?
