lets talk about ridetech #2625327
02/24/19 04:33 AM
02/24/19 04:33 AM
Lethbridge, AB, Canada
dangina Offline OP
dangina  Offline OP
I am curious as to those who are using this system - is it as great as they say it is? I have seen them do well at track days I am curious as to how they work? I know its just air shocks but how do you adjust for bumpsteer at different ride heights? also how do the rear shocks work in place of rear springs? what I mean I know with coilovers and leafs you pick the rate you want but how do these adjust rear rates? how do sway bars factor in?
Re: lets talk about ridetech [Re: dangina] #2625340
02/24/19 10:34 AM
02/24/19 10:34 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
It was the most problematic system on my Dad's Overhaulin setup. Perhaps it was the hasty install, but it ate a couple of air valves, rear shocks and I think the backseat bracing started to pull out of the floor.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: lets talk about ridetech [Re: dangina] #2625412
02/24/19 01:28 PM
02/24/19 01:28 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
You really don't, and the limitation there should be obvious.
Re: lets talk about ridetech [Re: jcc] #2625725
02/25/19 01:32 AM
02/25/19 01:32 AM
dangina Offline OP
dangina  Offline OP
what is the rear rate of their springs then?
Re: lets talk about ridetech [Re: dangina] #2625814
02/25/19 01:00 PM
02/25/19 01:00 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Maybe we are talking two different things, I was assuming you were thinking more rear "air springs" , their rate is based on fixed air chamber effective area, although some are have varying dimensions to allow some varying rate, and PSI, changing PSI which changes ride height when no other adjustments are made. Any conventional actual spring rates offered I can't comment on.
Re: lets talk about ridetech [Re: dangina] #2627357
03/01/19 01:12 AM
03/01/19 01:12 AM
dangina Offline OP
dangina  Offline OP
I can't be the only one on the fence about this! does the scca rules care if you use them?
Re: lets talk about ridetech [Re: dangina] #2627559
03/01/19 03:13 PM
03/01/19 03:13 PM
Pikes Peak Country
TC@HP2 Online content
TC@HP2  Online Content
Pikes Peak Country
It depends. In Production or Touring classes, not allowed. In CAM classes, allowed.
Re: lets talk about ridetech [Re: dangina] #2627926
03/02/19 02:57 PM
03/02/19 02:57 PM
dangina Offline OP
dangina  Offline OP
looking at this option as the next step in evolution - I would love to change ride height on the fly - but don't really want to sacrifice spring rates
Re: lets talk about ridetech [Re: dangina] #2627955
03/02/19 04:18 PM
03/02/19 04:18 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Just get Ridetech then and run in one of the CAM classes as SCCA. It's an open class. Tommwheels here built a 300hp Valiant and beat 500-700hp Camaros. It's not all about the suspension, but the driver.
Re: lets talk about ridetech [Re: dangina] #2627992
03/02/19 06:08 PM
03/02/19 06:08 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Not as many good solutions on the rear, but on the front, you might be able to craft a few multi mounting locations on the air spring on one end and vary the motion ratio. I toyed with thess idea, but not enough bang for the buck IMO.
Re: lets talk about ridetech [Re: dangina] #2628001
03/02/19 06:49 PM
03/02/19 06:49 PM
dangina Offline OP
dangina  Offline OP
still thinking of doing this someday:
https://rick486.wixsite.com/dobbertinperformance
