Width between stock rear frame rails? 65 Dart #2627696
03/01/19 10:56 PM
03/01/19 10:56 PM
gregsdart Offline OP
I would go out and measure, but laid up, back surgery. Anybody know what the width is between the rear frame rails on my 65 Dart? It is getting a Mustang EFI gas tank! The tank body is 29.5 long, 24 wide. I want to mount it with the long width spanning the rails, if possible.
Re: Width between stock rear frame rails? 65 Dart [Re: gregsdart] #2627707
03/01/19 11:17 PM
03/01/19 11:17 PM
Happy Birthday RapidRobert  Offline
I ain't gotta a direct ans for you but you might Google/ebay & see if there is a listed dimention for the A body tank. EDIT & if no luck I bet the FABO guys would know.
Re: Width between stock rear frame rails? 65 Dart [Re: gregsdart] #2627711
03/01/19 11:26 PM
03/01/19 11:26 PM
Itried all kinds of search words, no luck . If nobody answers hear, then FABO should be able to help.
