Removing Steering Column & Dash from A-body #262747
03/23/09 08:44 AM
03/23/09 08:44 AM
Anonymous OP
Anonymous OP
Vehicle is a 1970 Dart.
1) Read another post that mentioned a 5/16" roll pin to disconnect the column from the box... That was going to be my first question, "Size of punch required". So unless told otherwise I will assume this is correct (sounds about right)...?
2) I'm going to replace the wiper pivot gaskets. Should I just use the valve stem seal trick, or is there something better now?
I've "tilted-back" the dashboard on many other Chrysler products, but never an A-body. On a C-body there are screws at the edges of the defrost ducts that hold the dashboard in at the top. I don't see anything like this on the Dart. Where should I look for those screws?
Thanks.
Re: Removing Steering Column & Dash from A-body #262748
03/23/09 08:46 AM
03/23/09 08:46 AM
NJ
440challenger Offline
NJ
almost positive on an a body you have to take the front windshield out to get to the dash bolts on the top
Re: Removing Steering Column & Dash from A-body [Re: 440challenger] #262749
03/23/09 08:49 AM
03/23/09 08:49 AM
Anonymous OP
Anonymous OP
Gadzooks! If that's the case, this dashboard will not be removed!
Advantage C-body!
Re: Removing Steering Column & Dash from A-body [Re: 440challenger] #262750
03/23/09 08:52 AM
03/23/09 08:52 AM
ontario, canada
cool_cuda Offline
cool_cuda  Offline
ontario, canada
A bodies you dont have to take the glass out! as for the screws there are a couple place about 6-8inchs apart starting at each side of the A-pillars Have to taken out the glove box that may make it easier to see in there
Re: Removing Steering Column & Dash from A-body [Re: cool_cuda] #262751
03/23/09 08:55 AM
03/23/09 08:55 AM
NJ
NJ
Ok, sorry dont listen to me its been a while. I just rember the bolts being "hidden"
Your trying to take the frame out/ lean it back correct? Not just the dash pad....
Re: Removing Steering Column & Dash from A-body [Re: cool_cuda] #262752
03/23/09 09:15 AM
03/23/09 09:15 AM
Anonymous OP
Anonymous OP
I would assume means removing the instrument cluster on the other side... By that point it hardly seems worth removing the dash. (I'm not painting it or anything) just looking for easy access to the wiper pivots, and would check the heater core while I was there.
Re: Removing Steering Column & Dash from A-body #262753
03/23/09 09:31 AM
03/23/09 09:31 AM
Mt.Washington,KY
71ChargerSE Offline
71ChargerSE  Offline
Mt.Washington,KY
I just took the dash pad out of my 74 Duster and you can see the wiper pivots through some fairly large holes in the dash frame.To remove the pad you just have to reach up and remove nuts from underside of the pad and a screw on each end.The windshield does have to come out to remove the entire dash.
Re: Removing Steering Column & Dash from A-body [Re: 71ChargerSE] #262754
03/23/09 09:38 AM
03/23/09 09:38 AM
Anonymous OP
Anonymous OP
These being the instrument panel and glove box holes, correct? I have no need to remove the pad, it's in perfect shape.
Any thoughts on what I should use for the pivot gaskets?
Re: Removing Steering Column & Dash from A-body #262755
03/23/09 09:49 AM
03/23/09 09:49 AM
Southern Maryland
klunick Online content
klunick  Online Content
Southern Maryland
I thought they made a kit for the gaskets and the rubber. At least that is what I bought but I haven't installed anything yet.
67 Barracuda FB 69 Superbee "Southern Maryland: If you want a good looking woman, you had better bring her with you"
Re: Removing Steering Column & Dash from A-body [Re: klunick] #262756
03/23/09 09:53 AM
03/23/09 09:53 AM
NJ
NJ
I thought the windshield had to come out to get to the frame
I used small block chevy valve stem seals on my 68rr. Worked great!
Re: Removing Steering Column & Dash from A-body [Re: 440challenger] #262757
03/23/09 09:58 AM
03/23/09 09:58 AM
Anonymous OP
Anonymous OP
That's what I'll use then... A "real" parts store should sell them individually, I think.
I was just thinking about UV effect on a rubber part not designed for sunlight, but I suppose it would last as long as the OEM or resto parts. I don't really need any other gaskets from a kit, just these.
Re: Removing Steering Column & Dash from A-body #262758
03/23/09 10:21 AM
03/23/09 10:21 AM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
the only way to remove the dash without removing the glass is to cut the screw out and then re-install smaller ones upside down.
it can be done but i recomend removing the windshield
anyways,as said before if you remove the dash pad there are large holes in the dash to access behind it.
