Re: Engine Deck Height Tool - What are you using ?
[Re: vinnyd76]
#2627050
02/28/19 12:32 PM
02/28/19 12:32 PM
Posts: 2,639 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
You can use an ordinary outside micrometer with a ball attachment on the end. Imports can be bought cheap or on ebay. It won't get everywhere you want but it will give you an idea.
BHJ used to sell a dial caliper with a radiused attachment on the fixed jaw that worked but they were pricy.
2011 Drag Pak Challenger
[Re: vinnyd76]
#2627251
02/28/19 09:43 PM
02/28/19 09:43 PM
Posts: 31,016 Oregon
AndyF
Curious to see what the Mopar community is using to perform a simple engine block deck height check. Outside of taking a block to an engine shop, what measuring device are you using to check engine deck heights? Depends how accurate of a measurement you want. If you want a good measurement you need a large outside micrometer. If you don't have one of those you can use a machinist scale and read it within 0.010 of an inch depending on how good your eyes are.
[Re: 6PakBee]
#2627255
02/28/19 09:49 PM
02/28/19 09:49 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
As do I, but don't know if the OP is asking how to determine a block's deck height from the crank centerline, or getting an accurate measurement of how far below (or above) the deck the pistons are at TDC. Don;t think the OP knows either
[Re: Supercuda]
#2627380
03/01/19 02:41 AM
03/01/19 02:41 AM
Posts: 4,313 Prospect, PA
BSB67
Prospect, PA
As do I, but don't know if the OP is asking how to determine a block's deck height from the crank centerline, or getting an accurate measurement of how far below (or above) the deck the pistons are at TDC. Don;t think the OP knows either Certainly the question could be more clear
[Re: 451Mopar]
#2627533
03/01/19 02:34 PM
03/01/19 02:34 PM
BradH
12" dial caliper from main bearing bore to deck, then add 1/2 the bearing bore diameter. Got any feel for the accuracy of that approach? It's obviously correct mathematically, but how about getting consistent & usable measurements? Not looking to bash at all; I have a machined block that already needed some work redone by a different shop. One of questions I have is the deck height, especially if I need to order new pistons for the build.
[Re: AndyF]
#2627633
03/01/19 06:40 PM
03/01/19 06:40 PM
Posts: 10,711 North Dakota
6PakBee
North Dakota
A dial caliper is fine for determining if a block has already been decked. But for something more precise, installing the entire rotating/reciprocating assembly and checking every piston not only gives you a figure for the deck height but insight into how uniform the final rod/piston length is for each cylinder. I mean in the end, what are you really trying to accomplish, a certain deck height (crank centerline to block face) or a desired piston height (piston crown to block face)?
[Re: 6PakBee]
#2627659
03/01/19 08:37 PM
03/01/19 08:37 PM
RapidRobert
I'm assuming you want piston to deck distance for (A) a SCR number and (B) possibly achieving quench (.040). As said I would FIRST mockup the short block & measure all of em (as said the deck bridge/micrometer works OK) or at least the corners which will tell you how much to mill the block & you can potentially swap rods around if that will get em all more even or alter the rod C to C lengths slightly when you have them rebuilt & that is much more critical IF you are desireing quench as opposed to just getting a reasonable SCR number, then dissassemble it all for final balancing. Alot of work but when the long block is right it is right & with the right cam/intake/carb/converter & ign tuning & some spot on tuning you will have the BEST combo that YOU are capable of producing.
[Re: AndyF]
#2627977
03/02/19 05:18 PM
03/02/19 05:18 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
A 12" dial caliper would get you close but not precise due to the curve on the main bearing housing. But it should be within 0.005 of the actual number if you're careful. The number you get will be bigger than the real number. Like Andy said. You want to use the outer edge of the caliper that is narrowed down and then find the minimum reading so you know your on the bearing bore part that is closest to the cylinder / square to the deck. That is the hardest part. I have a micrometer and dial bore gauge that I can use to measure the bearing bore, but usually I just look up the bearing outside diameter spec. I just use the measurement to check if the block has been cut and of the four corners are the same height. If I want the block decked for a specific piston to deck clearance, I just tell the machine shop and let then set it up.
