duster drive shaft length ?? #262621
03/22/09 11:09 PM
03/22/09 11:09 PM
s. e. pa.
calrobb2000 Offline OP
s. e. pa.
hi
does any one know the correct length for a duster drive shaft with a 8 3/4 rear and 727 trans ?
also same rear with 904 trans ?
thank you !
Re: duster drive shaft length ?? [Re: calrobb2000] #262622
03/23/09 12:33 AM
03/23/09 12:33 AM
The archives might have the duster wheelbase ( either (108" or 111") & the correct length for you
Re: duster drive shaft length ?? [Re: RapidRobert] #262623
03/23/09 12:54 AM
03/23/09 12:54 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
45" w/727
49" w/904
Re: duster drive shaft length ?? [Re: RobX4406] #262624
03/23/09 02:43 PM
03/23/09 02:43 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
How about with a 4 speed???
Where is this list in the tech archives????
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: duster drive shaft length ?? [Re: CJK440] #262625
03/23/09 05:50 PM
03/23/09 05:50 PM
RobX4406 Offline
RobX4406  Offline
Should be the same length as a 904
It's not in the archives that I've seen but the crappy 8.75 chart that is wrong is still there... go figure. off soapbox!
