What is the most amount of Build Sheets a car can have? #2625695
02/25/19 12:24 AM
02/25/19 12:24 AM
MA
ragtop Offline OP
ragtop  Offline OP
MA
What is the most amount of Build Sheets a 1970 Hamtramck car can have? Thanks.
Re: What is the most amount of Build Sheets a car can have? [Re: ragtop] #2625698
02/25/19 12:42 AM
02/25/19 12:42 AM
Burnsville MN
ClassicIronman Offline
Burnsville MN
I have found three matching broad cast sheets in my first 70 Challenger T/A, I recently took apart a 70 Satellite convertible and found 4 broadcast sheets, One under the front seat was for a Purple 440 6 pac car the carpet was still original as well as the floor pan so I found a 70 Fy1 Yellow hardtop RR one there and then I pulled the rear seat and in the bottom one I found a 70 dark green 318 convertible one and then luckily I found a perfectly preserved one in the top half of the the rear seat. What I have seen is the there can potentially be 5 sheets per car from my past experience. I am not aware of an official number but maybe someone else will know. I have found them taped to the back of the glove box on E-bodies but have not found one there on b-body as of yet and the number of original cars are getting slimmer.
john
Re: What is the most amount of Build Sheets a car can have? [Re: ClassicIronman] #2625752
02/25/19 03:39 AM
02/25/19 03:39 AM
Washington state
pinkmeepmeep Offline
Washington state
I found three build sheets in my T/A
Re: What is the most amount of Build Sheets a car can have? [Re: ragtop] #2625753
02/25/19 04:22 AM
02/25/19 04:22 AM
Alabama
BigMoneyLewis Offline
Alabama
3 or 4 would not be unheard of . Slightly off topic ,The most I ever found in one car , would have been a 71 Torino Cobra I once owned , about 8 sheets , but all different, consecutive sequence cars, still connected together in a stack under the carpet.
I have had several Mopars that I did pull 3 sheets from , usually 71-up B bodies , (back seat upper and back seat lower, then under the carpet).
The best "secret hiding place" to find a buildsheet on a 1970 Hamtramck car is inside the drivers bucket seat upper half , inside the springs behind the plastic back cover . Often times these will be the best preserved sheets you will find as well.
My FJ6 T/A had one here ,folded twice , it was in near mint condition.
Greg
gregward@mchsi.com phone 256-852-0955
Re: What is the most amount of Build Sheets a car can have? [Re: ragtop] #2625767
02/25/19 06:47 AM
02/25/19 06:47 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
My Hawaiian Superbee WM23V0A had 3
Two of my Challengers had 2
JH23H1B
JS23V0B
Re: What is the most amount of Build Sheets a car can have? [Re: ragtop] #2625774
02/25/19 08:29 AM
02/25/19 08:29 AM
FL
moparwizard Offline
moparwizard  Offline
FL
I found 5 in a 70 Charger R/T and 4 in a 70 Dart 340.
Re: What is the most amount of Build Sheets a car can have? [Re: ragtop] #2625842
02/25/19 01:56 PM
02/25/19 01:56 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
My '72 Cuda had at least 3. I have not gutted the rest of the interior so there MIGHT be more.
