Rich Edelebrocks
#2624647
02/22/19 12:37 PM
02/22/19 12:37 PM
Posts: 211 Halifax, VA.
moparjack44
Halifax, VA.
I am running 2 500 CFM Edelbrock carbs on my 1st Gen 392 Hemi. They are running so rich, they are eating up spark plugs like they were pop corn. A mechanic friend of mine says nothing can be done, it's the natuer of running 2 4's. I don't want to accept that. Any suggestions to improve, or eliminate this situation?
K.I.S.S.
Re: Rich Edelebrocks
[Re: Supercuda]
#2624669
02/22/19 01:27 PM
02/22/19 01:27 PM
moparjack44
Halifax, VA.
Will check to confirm, but I am almost positive mine are the Performer series? I've had them for about 4 years?
K.I.S.S.
[Re: moparjack44]
#2624688
02/22/19 02:10 PM
02/22/19 02:10 PM
moparjack44
Halifax, VA.
Will check to confirm, but I am almost positive mine are the Performer series? I've had them for about 4 years? Both are 8867, but one has electric choke? On the base plate of each, is stamped F 2 X 4.
K.I.S.S.
[Re: moparjack44]
#2624693
02/22/19 02:20 PM
02/22/19 02:20 PM
RapidRobert
my eddy 1406 was lean & the choke came off way too fast. check your needle/seat(s). waterlogged float(s). float hanging up. fuel psi
[Re: moparjack44]
#2624710
02/22/19 02:39 PM
02/22/19 02:39 PM
moparjack44
Halifax, VA.
When adjusting fuel/air mixture, should both carbs be excatly the same, or adjust as individual carbs?
K.I.S.S.
[Re: moparjack44]
#2624739
02/22/19 03:40 PM
02/22/19 03:40 PM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
Both carbs HAVE to be synced or you will never get them to work right. It take patience and a bit of trial and error to get right. This Guide will help you and save me from typing it all out. Running rich is bad and your buddy should feel bad for that mistaken advise. Having one carb rich and another lean is worse. A broadband a/f gauge is a very good tool, but you should be able to get close without one. YouTube has vids to help out as well. HTH, Steve
[Re: Skeptic]
#2624761
02/22/19 04:24 PM
02/22/19 04:24 PM
Posts: 5,141 East Aurora (Buffalo) NY
RoadRunner
Both carbs HAVE to be synced or you will never get them to work right. It take patience and a bit of trial and error to get right. This Guide will help you and save me from typing it all out. Running rich is bad and your buddy should feel bad for that mistaken advise. Having one carb rich and another lean is worse. A broadband a/f gauge is a very good tool, but you should be able to get close without one. YouTube has vids to help out as well. HTH, Steve Thanks a ton. I have a Hemi with a cross ram that is way out of tune. I was looking for a document like this as doing some tuning is first thing on my list this spring. I was pretty good at tuning a single four and did a pretty good job with the 6 pack (found the guide from someone here). Moparts comes through again.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: Skeptic]
#2624769
02/22/19 04:43 PM
02/22/19 04:43 PM
moparjack44
Halifax, VA.
Both carbs HAVE to be synced or you will never get them to work right. It take patience and a bit of trial and error to get right. This Guide will help you and save me from typing it all out. Running rich is bad and your buddy should feel bad for that mistaken advise. Having one carb rich and another lean is worse. A broadband a/f gauge is a very good tool, but you should be able to get close without one. YouTube has vids to help out as well. HTH, Steve Great info. Something I think even an idiot (that would be me) can understand, and do. Thanks.
K.I.S.S.
[Re: moparjack44]
#2624774
02/22/19 04:58 PM
02/22/19 04:58 PM
Posts: 43,373 Bend,OR USA
Cab_Burge
Are you running them with both working at the same time, one to one linkage, or with progressive linkage? You probably need to lean down the metering rods on the primary step, the bigger step up high, to get it to run good at light part throttle cruise ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) I would adjust the primary idle mixture screws so it is as lean as possible and still start and idle okay with no stumble from driving away from a idle. What spark plugs brand and part numbers are you using now and how much compression on your motor? The new Eddy carbs are not as good as they use to be ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) You can get them to work excellent with enough tuning, so good they should knock the tires off at will at WOT ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: moparjack44]
#2624800
02/22/19 05:41 PM
02/22/19 05:41 PM
moparjack44
Halifax, VA.
One to one, come in together. NGK plugs/Autolite 65. The car runs and idles good. Exhaust tips black as coal, exhaust will burn your eyes, and foul the plugs. I just replaced the Autolite 65 with the NGK equivalent, but I don't remember the number.
K.I.S.S.
[Re: moparjack44]
#2624809
02/22/19 05:52 PM
02/22/19 05:52 PM
moparjack44
Halifax, VA.
I started with 650's. Too much carb, switched to 600's. Too much carb, went to the 500's. Runs much better. 2 X 500 = 1000, that's a lot of cfm's. The engine is mild, only bored 30 over to clean up the block, and mild cam. Stock iron heads, stock exhaust manifolds, factory Weiand intake. I built it to drive, not to race, or win trophy's or burn out contest.
K.I.S.S.
[Re: moparjack44]
#2624818
02/22/19 06:05 PM
02/22/19 06:05 PM
Cab_Burge
Try tuning the primary rods on the large step by making it larger in diameter by .002 to .006 or so and see if that helps, keep tuning it until your happy How much timing at idle and how much total timing? I cut my teeth( a long time ago back in the early to mid 1960s) on tuning the first gen Hemi Chrysler Firepower motors, 331,354 and 392 300 letter series motors Good luck ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: 2boltmain]
#2624825
02/22/19 06:16 PM
02/22/19 06:16 PM
moparjack44
Halifax, VA.
Fuel psi is critical. IIR Edelbrocks cannot have more 6 psi. I'm running 4 psi, Holley electric pump, Moon Eyes gauge. I lean toward the old stuff, moon eyes, stewart warner, etc. I also name my cars (car now). It's a 48 DeSoto, named Odd rOd. The O's are capital letters, and they are painted (no decals) like the moon eyes.
K.I.S.S.
[Re: moparjack44]
#2624829
02/22/19 06:25 PM
02/22/19 06:25 PM
Posts: 3,916 usa
lewtot184
usa
I started with 650's. Too much carb, switched to 600's. Too much carb, went to the 500's. Runs much better. 2 X 500 = 1000, that's a lot of cfm's. The engine is mild, only bored 30 over to clean up the block, and mild cam. Stock iron heads, stock exhaust manifolds, factory Weiand intake. I built it to drive, not to race, or win trophy's or burn out contest. a carb cannot make 0ne cfm. cfm ratings are for dummies. you've got something wrong besides the carbs.
[Re: moparjack44]
#2624919
02/22/19 11:26 PM
02/22/19 11:26 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
8867 isn't the carb number. the carb number is stamped as below ![](http://st.hotrod.com/uploads/sites/21/2017/01/edelbrock-carburetor-2.jpg)
[Re: Supercuda]
#2624944
02/23/19 12:10 AM
02/23/19 12:10 AM
moparjack44
Halifax, VA.
8867 isn't the carb number. the carb number is stamped as below Only number. I checked there first, only numbers there was the F 2X4. The 8867 was stamped on top plate, left rear (driver side).
K.I.S.S.
