What would cause my starter to break? #262372
03/22/09 09:18 PM
03/22/09 09:18 PM
So Cal
HealthServices Offline OP
Why would you even post that?
So Cal
440 with a mini starter.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: What would cause my starter to break? [Re: HealthServices] #262373
03/22/09 09:21 PM
03/22/09 09:21 PM
md
mopars4ever Offline
mopars4ever  Offline
md
made in china?
Re: What would cause my starter to break? [Re: mopars4ever] #262374
03/22/09 09:28 PM
03/22/09 09:28 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Stu had a similar failure last week, but the extra part bounced around the bellhousing some...
Re: What would cause my starter to break? [Re: mopars4ever] #262375
03/22/09 09:32 PM
03/22/09 09:32 PM
So Cal
So Cal
I thought they were all made in china
Just don't want the new one to break too.
I found his post. Funny how quickly the threads get pushed back.
Re: What would cause my starter to break? [Re: HealthServices] #262376
03/22/09 10:04 PM
03/22/09 10:04 PM
IA
landon1 Offline
landon1  Offline
IA
i had one do that....no idea what happened...took it back to the store and they weren't going to exchange me or even give me a core fee, but they did - i still had their original box
Re: What would cause my starter to break? [Re: landon1] #262377
03/22/09 10:08 PM
03/22/09 10:08 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Was it a rebuilt one or a new one? How long had it been installed?
Did it rub up against the block? Wasn't there some deal about mini starters and big blocks. Lie you had to grind the block for clearance or get a certain mini starter?
Re: What would cause my starter to break? [Re: autoxcuda] #262378
03/22/09 10:11 PM
03/22/09 10:11 PM
IA
landon1 Offline
landon1  Offline
IA
mine was a standard rebuilt piece from the parts store...only been on maybe 6 months at the most
Re: What would cause my starter to break? [Re: autoxcuda] #262379
03/22/09 10:18 PM
03/22/09 10:18 PM
Kirkland, Washington
Pacnorthcuda Offline
Thats a good point. If there was ANY contact with the block the starter bolts could have induced tremendous pressure on the snout as it was tightened down.
Re: What would cause my starter to break? [Re: Pacnorthcuda] #262380
03/22/09 10:22 PM
03/22/09 10:22 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Check out this thread from the tech archives. It might give you an idea. http://www.moparts.org/Tech/Archive/elec/1.html
Re: What would cause my starter to break? [Re: autoxcuda] #262381
03/22/09 10:31 PM
03/22/09 10:31 PM
So Cal
So Cal
I have these wonderful Hedman 2-1/8 headers that touched the starter.
So when I replaced it this last time I dented the header so they would not touch. and wrapped the tube with heatwrap.
Last long Mini touch but did not break. This short mini did not touch but broke.
I just put a RobbMC starter in today.
Re: What would cause my starter to break? [Re: HealthServices] #262382
03/22/09 10:45 PM
03/22/09 10:45 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Nope, just the cheap junk ones
Re: What would cause my starter to break? [Re: mopars4ever] #262383
03/22/09 10:52 PM
03/22/09 10:52 PM
So Cal
So Cal
Well the RobbMC starter looks pretty nice. I forgot but I think they use the Hitachi motor vs. the Nippondenso.
Hopefully I won't have this problem again they certainly don't look like they will get heat soaked. The big plus is they can be clocked into any position as long as it does not hit something.
Re: What would cause my starter to break? [Re: HealthServices] #262384
03/23/09 07:57 AM
03/23/09 07:57 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
this is the third (or maybe 4th) post ive seen about broken snouts on the mini starter
Re: What would cause my starter to break? [Re: HealthServices] #262385
03/23/09 11:31 AM
03/23/09 11:31 AM
Carson City, Nevada
RobbMc Offline
RobbMc  Offline
Carson City, Nevada
Thanks HS. We use US designed Remy (f.k.a. Delco Remy) motors and solenoids. Everything forward of the motor is our own design.
You should have a lot more header clearance with our starter. Not only can you rotate the solenoid to any position, but our motor is directly behind the pinion gear on the starter (rather than offset to one side). This puts the motor closer to the block, approximately where the solenoid is on your old Denso style starter.
Designing a better mouse trap always seems to lead to the evolution of smarter mice. www.robbmcperformance.com
Re: What would cause my starter to break? [Re: RobbMc] #262386
03/23/09 12:47 PM
03/23/09 12:47 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I got one likes that and two broken ring gears. made in china and was misaligned.
Re: What would cause my starter to break? [Re: HealthServices] #262387
03/23/09 01:05 PM
03/23/09 01:05 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
One issue I have noticed is the top hole is much bigger than a clearance hole and if that top bolt loosens it will allow the starter to walk some, but even the gear reductions are like this so is it an issue ???
Hopefully the rob mc addresses this or at leat what looks like a billet snout is stronger than the cast one on the mini. ???
Re: What would cause my starter to break? [Re: JohnRR] #262388
03/23/09 01:11 PM
03/23/09 01:11 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
If it makes you feel better I just pulled mine off yesterday when I was changing headers.......cracked on the snout! Luckily I had a back-up ready to go.
Always have an extra starter!
Re: What would cause my starter to break? [Re: Viol8r] #262389
03/23/09 01:47 PM
03/23/09 01:47 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
been there, done that! the top hole on those starters is too large for a 7/16 stud or bolt. sleeve the top hole for a 7/16 fastener and the problem is cured. i think what happens is the starter kicks or torques over from a hard start or backfire and the big top hole lets it rotate enough to snap the locating snout. the snout is just a locater and isn't meant to carry a load.
Re: What would cause my starter to break? [Re: JohnRR] #262390
03/23/09 02:00 PM
03/23/09 02:00 PM
So Cal
So Cal
Re: What would cause my starter to break? [Re: RobbMc] #262391
03/23/09 02:09 PM
03/23/09 02:09 PM
So Cal
So Cal
mini long
and
mini short
RobMC
Tons more room
This is the same 2-1/8" header tube!
