Cowl gauge mounting #262369
03/22/09 09:17 PM
03/22/09 09:17 PM
Nova Scotia, Canada
jeff_past Offline OP
Nova Scotia, Canada
Hey guys, just wondering how you all are mounting gauges on the cowls or outside of your cars? I've seen the way by bending a vent grill bar up and using that, but i would rather not go that route.
Any ways that i've been missing?
Re: Cowl gauge mounting [Re: jeff_past] #262370
03/22/09 09:55 PM
03/22/09 09:55 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
We used a small piece of sheet aluminum,bent so that the gauge sits on the metal and bent a lip so that it attaches between the cowl and the hood.The lip attaches where the washer hoses normally ran.We also used a steel line for the gauge and ran it thru the nozzle hole,and between the vent bar.No bending necessary!!
Nautilus Racing-
Re: Cowl gauge mounting [Re: Chris2581] #262371
03/23/09 10:03 AM
03/23/09 10:03 AM
Nova Scotia, Canada
Nova Scotia, Canada
Thanks that seems like it should be pretty easy to do.
