ebay manual steering boxes?
#2623285
02/19/19 01:11 PM
02/19/19 01:11 PM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
Anyone have an experience w/ these boxes? Seems like a good deal. https://www.ebay.com/itm/New-1966-1979-M...x/322896156125?I need to either rebuild the one in my '70 cuda or get one already rebuilt. From past experience and aggravation, I'd rather not do this myself. So it's either send my current box out to be rebuilt or replace it. Thoughts?
Re: ebay manual sterring boxes?
[Re: JMCFAN]
#2623294
02/19/19 01:34 PM
02/19/19 01:34 PM
an8sec70cuda
What'd it cost you? How long did it take?
[Re: an8sec70cuda]
#2623369
02/19/19 04:00 PM
02/19/19 04:00 PM
Posts: 2,094 New Mexico
JMCFAN
New Mexico
What'd it cost you? How long did it take? 3-4 weeks.... $300
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
[Re: an8sec70cuda]
#2623380
02/19/19 04:39 PM
02/19/19 04:39 PM
an8sec70cuda
dogdays...I agree on the "brospeed" name deal, but I've seen others selling boxes similarly priced. The only steering box I've messed with was on a tractor and it was a PITA. Never been into a car box.
The Flaming River boxes are cast iron AFAIK, so that's a no for me.
I looked on rockauto but didn't see an option for a complete steering box? Saw some rebuild kits, but no box.
[Re: dogdays]
#2623385
02/19/19 05:11 PM
02/19/19 05:11 PM
Posts: 8,680 Buford, GA
I_bleed_MOPAR
Buford, GA
My initial reaction was that a manual box isn't that complicated and can usually be rebuilt by an amateur. There isn't really all that much to them. I rebuilt my Saginaw 525 box in a parking lot.
R. Not a whole lot to a manual box. IIRC, the bushing vs. bearing goes back to mid-60s? when the changeover took place. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: I_bleed_MOPAR]
#2623661
02/20/19 12:53 PM
02/20/19 12:53 PM
I_bleed_MOPAR
Buford, GA
What is it that makes you think yours needs an overhaul? Too much freeplay in steering wheel? Inquiring minds want to know. Tim
[Re: I_bleed_MOPAR]
#2623726
02/20/19 03:09 PM
02/20/19 03:09 PM
RapidRobert
^^^ there's the stud/nut on top & the big castelleted? nut on the rear & they need to be adjusted in order (shop manual) & (ideally) fill it with Ehrenbergs concoction
[Re: I_bleed_MOPAR]
#2623845
02/20/19 06:37 PM
02/20/19 06:37 PM
an8sec70cuda
What is it that makes you think yours needs an overhaul? Too much freeplay in steering wheel? Inquiring minds want to know. Tim It's the almost 50 year old original box that's never been off the car. Has a good bit of play in it and I've tightened it up a couple times already. I'd like to get as much play out of the steering dealing w/ wheelstands/landings at the track.
[Re: an8sec70cuda]
#2623873
02/20/19 07:21 PM
02/20/19 07:21 PM
Posts: 5,164 CT
GTX MATT
CT
It was me that had the thread 2 years ago. I bought it from a different vendor and it was a little more, but I haven't had any issues with mine. The quality seemed good. Actually fit fine, came packed with grease, and looks identical to the factory box it replaced.
[Re: GTX MATT]
#2624037
02/21/19 12:50 AM
02/21/19 12:50 AM
RapidRobert
We went from a 24 to a 16:1 manual on the stock car & it was night & day in the corners (before it was hand over hand nonsense). Not sure if it would be recommended for the street but check into that (iirc people said parallel parking was hard (you can live with that) & that with skinny tires daily driveing was manageable).
[Re: an8sec70cuda]
#2624050
02/21/19 01:37 AM
02/21/19 01:37 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Click the link
[Re: an8sec70cuda]
#2624119
02/21/19 11:23 AM
02/21/19 11:23 AM
an8sec70cuda
GTX Matt...thankyou for the info.
RapidRobert...I think I want to stick w/ the 24:1 that I'm used to. I don't want it to react real fast.
Supercuda...thanks! I swear I looked at all the options when I did the search, guess not.
[Re: an8sec70cuda]
#2624130
02/21/19 11:41 AM
02/21/19 11:41 AM
Supercuda
About to go away
About to go away
up yours
If you go that route let us know how it went.
