426 Wedge Funky Main Caps? #2623162
02/19/19 12:56 AM
02/19/19 12:56 AM
North East USA
BIGGERED Offline OP
Reasonable Title
BIGGERED  Offline OP
Reasonable Title
North East USA
What is going on with this block a guy is asking about on forkbook?
2 14 63 2406730-1
Just curious as I’ve never seen this before!
TY
Red
Re: 426 Wedge Funky Main Caps? [Re: BIGGERED] #2623169
02/19/19 01:03 AM
02/19/19 01:03 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Looks like aftermarket caps, but I am in no way an expert.
Re: 426 Wedge Funky Main Caps? [Re: BIGGERED] #2623178
02/19/19 01:24 AM
02/19/19 01:24 AM
AndyF Offline
AndyF  Offline
It is just a set of homemade support straps.
Re: 426 Wedge Funky Main Caps? [Re: BIGGERED] #2623179
02/19/19 01:26 AM
02/19/19 01:26 AM
That is one of the old race "tricks" band aids to try and stiffen up the bottom end, if your interested in making the bottom end stronger go to a set of after market aluminum main caps and a set of ARP main studs up twocents
The old time drag racers started doing that back in the 1950s or so to every V8 motor out there hey where trying to make the bottom end stronger on including 265 V8 C.I. Chevy and the older Ford V8 flat heads and the early Mopar first gen hemi motors shruggy
Re: 426 Wedge Funky Main Caps? [Re: BIGGERED] #2623254
02/19/19 11:44 AM
02/19/19 11:44 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
flat head fords used to be done like that. just a band-aid.
Re: 426 Wedge Funky Main Caps? [Re: BIGGERED] #2623257
02/19/19 11:55 AM
02/19/19 11:55 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
In reality doing that actually made the cap much more prone to distortion under load and cracking - that was a modification of the day along with grooving the mains on the crank for better oiling. Nice history piece - but I would replace the caps with aluminum ones
Re: 426 Wedge Funky Main Caps? [Re: DoubleD] #2623364
02/19/19 03:54 PM
02/19/19 03:54 PM
dogdays Offline
dogdays  Offline
Agreed. I'm surprised that the picture didn't include a couple of boxed rods lying around. That was done to everything as well. Cut pieces of sheet metal to the outline of the rod and weld them to the edges of the flanges of the connecting rods. It supposedly made the rods stronger.
R.
