Re: How to get code off this fender tag ?
[Re: ScottSmith_Harms]
#2623510
02/19/19 11:44 PM
02/19/19 11:44 PM
Posts: 142 Near Columbus, Ohio
++MAX WEDGE++
Near Columbus, Ohio
If you decide to soak it to remove the rust I'd recommend Evaporust not acid (vinegar). Also, Dan's tag decipher may be more accurate concerning the L25 vs M25. Does your car have a trunk light? Rocker moldings? Yes car has trunk lite. It does not have on it (currently) rocker moldings but that not to say they weren't there, I would have to check and see if there is clips there that might have held them on at one time. Is there a big difference between L25 and M25?
[Re: cdwmotorsports]
#2623515
02/19/19 11:53 PM
02/19/19 11:53 PM
++MAX WEDGE++
Near Columbus, Ohio
If ever there was a car that needed a new fender tag made.
What’s the rest of the car look like? Believe it or not it has a super solid frame and trunk.....crazy I know
#2623856
02/20/19 06:45 PM
02/20/19 06:45 PM
Posts: 4,321 St. Louis, Mo
318 Stroker
St. Louis, Mo
Probably not 100% accurate but with some interpretive guesswork this should be pretty close.
VL29: Plymouth Duster - Base/low level model G = 318 V8 2 = 1972 model year H = Plant = Hamtramck, MI, USA Scott, since we're trying to help him decipher his codes properly, I need to correct you. As you know, "H" would be the 340 engine code. "B" as the 7th digit would be the plant code for Hamtramck, not "H".
#2623899
02/20/19 08:29 PM
02/20/19 08:29 PM
++MAX WEDGE++
Near Columbus, Ohio
Absalutely, brain fart on my part. I was typing that fat fingered on my cell phone and made a few changes, scrambled it somehow. I fixed it. Any thoughts on production numbers with the "Twister Package" and What is a "Twister Package" ???? Thanks Scott
