Page 2 of 5 1 2 3 4 5
Re: 73 Charger won’t run, any help appreciated [Re: Sunroofcuda] #2620779
02/13/19 02:38 PM
02/13/19 02:38 PM
moparx Offline
moparx  Offline
so it cranks but won't start. have you established a GOOD 12v at the coil in the start position ? you can have a spark, yet not a GOOD spark.
beer
Re: 73 Charger won’t run, any help appreciated [Re: moparx] #2621919
02/15/19 11:41 PM
02/15/19 11:41 PM
Martinsville, IN
cdwmotorsports Offline OP
Martinsville, IN
beer
MoParx if it doesn’t have good spark what could the cause be?
I obviously have put on the new FBO box, and coil, bypassed ballast resistor and ensured the engine has a good ground to the body. The distributor shaft is not broke (I confirmed that today). The cap and rotor look good too. I have new unused set of MSD from a different small block project I could put on but I suspect the Mallory wires on it aren’t the issue.
If it warms up enough tomorrow I’m going to ensure the rotor turns as the engine is cranked, ensure timing is correct, ensure the engine is at tdc, check firing order of plug wires is correct.
Things I have accomplished with the 30 degree weather we’ve been having...
Replaced he fuel lines
New battery in
Nitrous system off of engine
New FBO stuff on
eBay-cdwmotorsports
Re: 73 Charger won’t run, any help appreciated [Re: cdwmotorsports] #2621921
02/15/19 11:43 PM
02/15/19 11:43 PM
Martinsville, IN
Martinsville, IN
Oh yeah and the oil and filter have been changed. Brakes have been checked and new soft lines are ordered just to be sure they are good, the brakes work great but will be gone through as soon as I figure out why it isn’t running.
eBay-cdwmotorsports
Re: 73 Charger won’t run, any help appreciated [Re: cdwmotorsports] #2621960
02/16/19 01:04 AM
02/16/19 01:04 AM
New Jersey
P
Powerflow Online content
Powerflow  Online Content
P
New Jersey
One quick way to check for a jumped timing chain is to disable the ignition and hold your hand over the carb while someone cranks the engine. If you get air puffing out of the carb there is an issue with the chain or you have a stuck valve(s).
Re: 73 Charger won’t run, any help appreciated [Re: Powerflow] #2622002
02/16/19 03:15 AM
02/16/19 03:15 AM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
are the plug wires connected in the correct direction for which engine you have???
my ladder of success is missing some rungs
Re: 73 Charger won’t run, any help appreciated [Re: cdwmotorsports] #2622098
02/16/19 01:12 PM
02/16/19 01:12 PM
moparx Offline
moparx  Offline
beer
New battery in
New FBO stuff on
without seeing under the dash, and looking at the bulkhead connectors, it "may" be a hidden [as in, yet to be detected] wiring problem. as you have said your brother [brother-in-law ?] has been playing with it, who knows exactly what may, or may not, have been done wiring wise.
beer
Re: 73 Charger won’t run, any help appreciated [Re: moparx] #2622099
02/16/19 01:15 PM
02/16/19 01:15 PM
Martinsville, IN
Martinsville, IN
beer
Thanks. Lucky for me I doubt my brother in law did much to the wiring. I will definitely look the under dash wiring and the bulkhead connections over.
eBay-cdwmotorsports
Re: 73 Charger won’t run, any help appreciated [Re: cdwmotorsports] #2622128
02/16/19 02:19 PM
02/16/19 02:19 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Why would you assume it doesn’t have oil or a filter? 30 years of messing with cars, it has oil.
Maybe this is why.
My parents let my ex brother in law jack with it so who knows what all isn’t right. Today I found the carb wasn’t bolted down.
My question is why would you question someone trying to help you? shruggy
Firing a motor that has sat for some time is relatively basic.
First thing I would do is drain and replace the oil & filter.
Next check for spark.
Check timing,
After that fuel is the only thing left.
Oh and if it sat a long time there might be something restricting the exhaust.
I have mechanical Aptitude.
I can screw up anything.
Re: 73 Charger won’t run, any help appreciated [Re: bboogieart] #2622306
02/16/19 09:38 PM
02/16/19 09:38 PM
Martinsville, IN
Martinsville, IN
Maybe this is why.
Check timing,
Why would I question someone trying to help me?
Well for one I’d say most of the people on any forum don’t read the full thread before replying, or they make statements that don’t help at all. Plenty of people on this board have egos and greater than thou attitudes assuming because someone asks for help that they haven’t already checked the most basic issues, including ensuring the fluids were good. Give me a break.
The worst are the old guys, the crotchety old guys are why this hobby is dying off. Young(er) people don’t want to be treated like their lesser than just because some old fart has been doing it with stock parts for 400 years or because a 9” rear-end is what they put in their Duster. Just answer the questions asked without your personal biases and move on, or if your an angry old a$$hole then don’t post at all.
eBay-cdwmotorsports
Re: 73 Charger won’t run, any help appreciated [Re: cdwmotorsports] #2622315
02/16/19 09:57 PM
02/16/19 09:57 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
Maybe this is why.
Check timing,
wow... you come on here asking for help....and then cop an attitude.. unbelievable... your TS skills suck...you try and fire and engine with carb cleaner... enough said...
what difference does age make....there are 15 year olds that would have already had that car running... lol
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: 73 Charger won’t run, any help appreciated [Re: cdwmotorsports] #2622321
02/16/19 10:02 PM
02/16/19 10:02 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
haha
Well Excuuuuuzzzzzzee me!
Re: 73 Charger won’t run, any help appreciated [Re: bboogieart] #2622323
02/16/19 10:06 PM
02/16/19 10:06 PM
Martinsville, IN
Martinsville, IN
haha
Why assume I was speaking of you?
eBay-cdwmotorsports
Re: 73 Charger won’t run, any help appreciated [Re: JMCFAN] #2622324
02/16/19 10:08 PM
02/16/19 10:08 PM
Martinsville, IN
Martinsville, IN
Maybe this is why.
Check timing,
Whatever TS skills are?
Also if you’ve ever watched Roadkill you’d understand the carb cleaner thing. Although I’m sure most here haven’t because they don’t build trailer/garage queen restos.
eBay-cdwmotorsports
Re: 73 Charger won’t run, any help appreciated [Re: cdwmotorsports] #2622326
02/16/19 10:12 PM
02/16/19 10:12 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
The worst are the old guys, the crotchety old guys are why this hobby is dying off. Young(er) people don’t want to be treated like their lesser than just because some old fart has been doing it with stock parts for 400 years or because a 9” rear-end is what they put in their Duster. Just answer the questions asked without your personal biases and move on, or if your an angry old a$$hole then don’t post at all. [/quote]
[/quote]
Also if you’ve ever watched Roadkill you’d understand the carb cleaner thing. Although I’m sure most here haven’t because they don’t build trailer/garage queen restos. [/quote]
trouble shooting.... and your car will not run on carb cleaner.... m
Re: 73 Charger won’t run, any help appreciated [Re: cdwmotorsports] #2622354
02/16/19 11:09 PM
02/16/19 11:09 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
If it were me, I'd do a compression check first. I'd bet it's got a piston out of it at least.
Re: 73 Charger won’t run, any help appreciated [Re: slantzilla] #2622371
02/16/19 11:41 PM
02/16/19 11:41 PM
Martinsville, IN
Martinsville, IN
Thanks, I had that as a suspicion also. If that’s the case it was done prior to us getting it as the NOS was disabled prior to us buying it. I will add it to the list of items to check. Unless it warms up soon it will be a bit before I go back to it.
eBay-cdwmotorsports
Re: 73 Charger won’t run, any help appreciated [Re: JMCFAN] #2622376
02/17/19 12:04 AM
02/17/19 12:04 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Could not agree more. That's why I quit a long time ago trying to help people with problems. Got to love it blame the stupid ex-brother in law.
Re: 73 Charger won’t run, any help appreciated [Re: NITROUSN] #2622385
02/17/19 12:31 AM
02/17/19 12:31 AM
Martinsville, IN
Martinsville, IN
The car stopped running properly after he drove it, there was not anything wrong with it prior to him driving it. My parents bought the car from CokeBottleKid (from here). I guess you know better than my parents and I about what has happened with the car since they bought it though. shake_head
eBay-cdwmotorsports
Re: 73 Charger won’t run, any help appreciated [Re: cdwmotorsports] #2622388
02/17/19 12:37 AM
02/17/19 12:37 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Most of "the crotchety old guys" on this site would have had that thing diagnosed in a day.
Re: 73 Charger won’t run, any help appreciated [Re: stumpy] #2622393
02/17/19 12:50 AM
02/17/19 12:50 AM
Martinsville, IN
Martinsville, IN
Yep and most aren’t likely attempting to do this outside in 30 degree temps. I however am as we have a single car garage not long enough to even house this car, let alone it being occupied by my wife’s Jeep.
eBay-cdwmotorsports
