383 Valve Covers #2619831
02/11/19 03:18 PM
02/11/19 03:18 PM
Los Angeles, CA
JF_Moparts Offline OP
Los Angeles, CA
It looks like I need a new valve cover for my 1971 Roadrunner 383. I have the original factory covers.
Does anyone know what other years/engines used the same valve cover? I've never had to replace a factory valve cover and have no idea which ones to look for. Thanks.
Re: 383 Valve Covers [Re: JF_Moparts] #2619849
02/11/19 03:53 PM
02/11/19 03:53 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
they had minor differences every model year, sometimes during the model year
for '71 there are "early" & "late" versions, match what you have - if they are originals
Re: 383 Valve Covers [Re: 6bblgt] #2619851
02/11/19 03:56 PM
02/11/19 03:56 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
what side do you need?
Re: 383 Valve Covers [Re: 6bblgt] #2619865
02/11/19 04:14 PM
02/11/19 04:14 PM
Los Angeles, CA
Los Angeles, CA
I have what's probably early, but I'll have to take a look. The car was built in 1970 and came with the older center console with the seat belt holder (instead of the ashtray). I just need the passenger side one.
Re: 383 Valve Covers [Re: JF_Moparts] #2619884
02/11/19 04:58 PM
02/11/19 04:58 PM
Los Angeles, CA
Los Angeles, CA
Here's a pic of the valve cover, passenger side. It looks like the later 1971 style.
Did you have one for sale? Thanks.
Re: 383 Valve Covers [Re: JF_Moparts] #2619911
02/11/19 05:54 PM
02/11/19 05:54 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
pull of the oil fil cap scope narrow-lip "early" or wide-lip "late"
I'll see what I have - what's wrong with yours?
Re: 383 Valve Covers [Re: 6bblgt] #2619918
02/11/19 06:10 PM
02/11/19 06:10 PM
Los Angeles, CA
Los Angeles, CA
Ok, will do.
Mine was leaking oil and I found a bunch of splits/cracks in the metal along the sides near the bolt holes. I'm seeing if a replacement can be found instead of trying to weld that thin metal.
Re: 383 Valve Covers [Re: JF_Moparts] #2619933
02/11/19 06:47 PM
02/11/19 06:47 PM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
Originally Posted By JF_Moparts
Ok, will do.
It was tightened down to much and caused the split holes. It looks like a 1970 Valve cover to me, but to be 100% you must take off oil cap like Dan said.
Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: 383 Valve Covers [Re: JF_Moparts] #2619934
02/11/19 06:56 PM
02/11/19 06:56 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Buy a NEW set from AMD...
Re: 383 Valve Covers [Re: DAYCLONA] #2619936
02/11/19 07:00 PM
02/11/19 07:00 PM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
Ask me how I know. Don't do that if you want them to fit. Holes are wrong, crease on top in stamping, oil cap is not clocked correct and does not fit tight.
Bob
Re: 383 Valve Covers [Re: JF_Moparts] #2619944
02/11/19 07:25 PM
02/11/19 07:25 PM
Los Angeles, CA
Los Angeles, CA
Here's a closeup of the oil hole. 1971?
Re: 383 Valve Covers [Re: JF_Moparts] #2619946
02/11/19 07:30 PM
02/11/19 07:30 PM
Los Angeles, CA
Los Angeles, CA
FYI - Here's a shot of the inner side, showing the wire harness tabs.
Re: 383 Valve Covers [Re: JF_Moparts] #2619947
02/11/19 07:30 PM
02/11/19 07:30 PM
Los Angeles, CA
Los Angeles, CA
Since I got another PM about it, the car is a mostly unrestored 110,000 mile car.
Re: 383 Valve Covers [Re: JF_Moparts] #2619950
02/11/19 07:34 PM
02/11/19 07:34 PM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
That looks like a 1970 to early 71. Late 71 has a larger raised circle.
Bob
Re: 383 Valve Covers [Re: VCODE] #2619964
02/11/19 07:49 PM
02/11/19 07:49 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
& if you notice the AMD RH valve cover doesn't have the same "divot" on the front of the passenger side
Re: 383 Valve Covers [Re: 6bblgt] #2619968
02/11/19 08:04 PM
02/11/19 08:04 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I do not have a RH valve cover that matches yours
here is the '71 big lip RH valve cover
yours appears to be the same one I should have on my mid-July '70 built Challenger R/T (LATE '70 & EARLY '71)
did yours have studs or bolts on the outside corners & what's the SPD & plant of your RR - do you also have the Engine Assembly Date (EAD) off the pad by the distributor?
Re: 383 Valve Covers [Re: 6bblgt] #2619970
02/11/19 08:07 PM
02/11/19 08:07 PM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
Dan,
I think what AMD did was make a 70 only and a late 71 only
The late 70 early 71 may have changed and they maybe did not make that one.
See my picture of the stamping crease.
Bob
Re: 383 Valve Covers [Re: 6bblgt] #2619992
02/11/19 08:51 PM
02/11/19 08:51 PM
Los Angeles, CA
Los Angeles, CA
Will the later 1971 valve cover fit and be functional? At this point I just want to get the car back together!
Re: 383 Valve Covers [Re: JF_Moparts] #2620006
02/11/19 09:25 PM
02/11/19 09:25 PM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
Yes, just looks a little different. Most at a local show will not notice.
Re: 383 Valve Covers [Re: VCODE] #2620062
02/11/19 11:55 PM
02/11/19 11:55 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
The AMD covers are $179 at Summit but now they charge tax in a bunch of states!
Ron
