Re: 73 Charger won’t run, any help appreciated
[Re: cdwmotorsports]
#2625696
02/25/19 12:26 AM
02/25/19 12:26 AM
Posts: 1,417 Martinsville, IN
cdwmotorsports
Martinsville, IN
Well I have now cleared the old tank of fuel and added a fresh 5 gallons. Filled the bowls and turned the key, it spit and sputtered, so I turned distributor 180 and it continued to spit and sputter. I walked away from it and it dawned on me the I put the wires on as if it was a big block fixed that and put the rotor back the 180 I had flipped it. It fired off a couple times and I’m pretty sure that we flooded it. The temperature here today was once again not conducive to firing it up. It’s supposed to be warmer tomorrow and Tuesday without the high winds we are currently having. The carb rebuild kit is due here Tuesday so that will be a project for the firehouse on Wednesday. The best thing is I’m pretty sure the problem has been fixed and it’s just a matter of getting it dialed in on the fresh carb.
eBay-cdwmotorsports
#2626527
02/26/19 10:59 PM
02/26/19 10:59 PM
cdwmotorsports
Martinsville, IN
It’s not running yet. I personally believe it is a multitude of issues all compounded into it not running.
eBay-cdwmotorsports
#2626709
02/27/19 01:32 PM
02/27/19 01:32 PM
Posts: 3,020 N.W. Florida
Fat_Mike
N.W. Florida
It’s not running yet. I personally believe it is a multitude of issues all compounded into it not running. Makes sense to me, as it quit running while your BIL was driving it (if I read your early comments correctly). In any case, keep plugging away at it and let us know as your progress continues.
[Re: SattyNoCar]
#2633542
03/17/19 08:13 AM
03/17/19 08:13 AM
cdwmotorsports
Martinsville, IN
Some sort of ignition issue. I replaced all the ignition parts one at a time box and coil "didn't" fix it, wires "didn't" fix it. New distributor and warm temps and it runs. With the cold though I can't be certain the problem wasn't solved prior to the new distributor because we flooded it out trying to start it in the 40 degree temps. Which sends me back to some sort of ignition problem.
eBay-cdwmotorsports
[Re: moparx]
#2634525
03/19/19 06:54 PM
03/19/19 06:54 PM
cdwmotorsports
Martinsville, IN
I have 6 plugs I need to get two more, they didn’t have the full set apparently when I got them. Hoping to get the other two on the way home in about an hour.
eBay-cdwmotorsports
[Re: moparx]
#2635889
03/23/19 11:34 AM
03/23/19 11:34 AM
cdwmotorsports
Martinsville, IN
Huge improvement, the miss is gone as is most of the stumble. I need to throw a timing light on it yet to dial it in. My eleven year old was driving me nuts yesterday asking if we could drive it I told him we would as soon as we changed the plugs. We swapped them and he got in the drivers seat and it fired right up no issue, I told him to get in passenger seat and he said he was gonna drive it, I said well not if he wanted to go out on the road. He suggested we check the air in the tires and asked if he could move it up to the garage, I caved and after I shifted the Hurst V-matic (man do I hate that shifter) into gear for him he was off. We took it for out for about a 15 minute drive, which is the furthest we have went yet and it performed great. I was obviously begged for a burnout so I provided two, not good ones since the BFG Radial T/A's are on they're last leg. Cooper tires are the next on the agenda to make it a safe cruiser and then it will be driven regularly while I park the truck.
eBay-cdwmotorsports
