Page 3 of 3 1 2 3
Re: New KB Blocks are moving [Re: The Shadow] #2619797
02/11/19 02:24 PM
02/11/19 02:24 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Im anxious to see mine when it arrives to compare it to the others I have. I am hoping they can be available on much shorter leads times in the future and that sounds like it will become a reality.
Re: New KB Blocks are moving [Re: The Shadow] #2619818
02/11/19 02:59 PM
02/11/19 02:59 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
The instant availability thing is such a huge part of sales. I know there are guys who plan every single thing they do, but I am certainly not one of them. Neither are most of my track buddies. Impulse projects, and buying, account for a large percentage of my purchases in racing. I don't think I'm alone in this, even outside my own biosphere.
I can think of at least 4 times in recent memory that I'd have jumped on some build tangent had blocks been available. The process was like, oh man, look at that. That would be a cool combo, what do the parts cost? OK, cool, doing mechanical math, getting the fire going. Then,,,,oh yeah,,,no blocks,,,what can I re cobble out of my existing junk.
Re: New KB Blocks are moving [Re: ChrgrCuda] #2619942
02/11/19 07:13 PM
02/11/19 07:13 PM
QLD Australia
Keith Black® Offline
QLD Australia
Originally Posted By ChrgrCuda
Darren - Great job on an awesome looking product!
Do you have your website up with available P/N's and prices?
I think you just put Mopar back in the game my friend.
thanks for the kind words.
MSRP for all blocks is $7495 (plus taxes & shipping)(all blocks are sold through our Dealers).
I am setting the price for the Pro blocks at the moment, so I will advise very soon when we have a landing number on costs.
Our website (which has perpetually been "under development" Lol.), has been waiting on photography of the new blocks, so expect to see this during February albeit it may be a little limited in content at first the essentials will be there.
Attached is a PDF of current P/N's & specifications.
cheers, DB
Attached PDF document
Darren Beale
Keith Black Racing Engines®
Re: New KB Blocks are moving [Re: The Shadow] #2619949
02/11/19 07:32 PM
02/11/19 07:32 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
I thought the blocks were $6995.00?
Did they go up?
Re: New KB Blocks are moving [Re: cdwmotorsports] #2619988
02/11/19 08:44 PM
02/11/19 08:44 PM
QLD Australia
QLD Australia
Originally Posted By cdwmotorsports
Darren I presume we are still in a holding pattern for the low deck wedges?
I am getting a costing together for low deck HEMI and WEDGE engine options now that we have a viable machining option. I will let everyone know when and what volume we need to make this work.
Darren Beale
Re: New KB Blocks are moving [Re: The Shadow] #2620040
02/11/19 11:01 PM
02/11/19 11:01 PM
AndyF Offline
AndyF  Offline
A low deck wedge seems fairly easy to accomplish, especially if you use the RB main bore. That saves you from having to design new main caps. There aren't a lot of low deck intake manifolds but perhaps if a block was available someone would step up with some killer intakes. If you stick with the RB main size then you avoid the low deck main bearing issue and you consolidate demand for RB crankshafts. Seems like a winner to me.
A low deck Hemi could be complicated by the pushrod angles. Might want to mock that one up and see if everything clears everywhere before you get too far into it. It seems like the pushrods already get into the cylinder bores at the RB deck height. If you lower the deck then the pushrods are going to lean over even more.
Re: New KB Blocks are moving [Re: AndyF] #2620048
02/11/19 11:31 PM
02/11/19 11:31 PM
QLD Australia
QLD Australia
Andy we can model-up the pushrod angles no sweat. the greater challenge is water jacket cores which have to be created from scratch, already the trickiest section on HEMI blocks.
Getting all the investment costs together on this now.
Darren Beale
Re: New KB Blocks are moving [Re: Keith Black®] #2620155
02/12/19 04:05 AM
02/12/19 04:05 AM
QLD Australia
QLD Australia
... some more pics
Engine Block Front Inverted (MED).jpgEngine Block RHF Bank (MED).jpgNo5 Main Bearing Cap Installed (MED).jpg
Darren Beale
Re: New KB Blocks are moving [Re: powertrip] #2620157
02/12/19 04:38 AM
02/12/19 04:38 AM
QLD Australia
QLD Australia
Originally Posted By powertrip
I have a question regarding the cooling. The coolant port on the deck to the water pump is clearly smaller than stock and restricting flow to the suction side of the water pump- is there a reason this could not be made larger? This is not where you want a flow restriction.
powertrip There are no issues with this. Best (worst?) kept secret in engine design world is that the thermal transfer properties of A356 is a large multiple of cast iron.
You can run blocks with skinny water jackets and still cool better.
Most of the cooling is in the cylinder head and top of the bore.
Darren Beale
Re: New KB Blocks are moving [Re: The Shadow] #2620187
02/12/19 09:54 AM
02/12/19 09:54 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I've never been a player in these new blocks, but that is a work of art. It seems to me that the price is going to be a bit cheaper than the original projections, too. Starting to make me rethink about getting a new block vs. overhauling my busted up old Indy block. What other processes will need to be done before assembly besides final piston sizing, honing and cleaning? Will cam bores and location go under "Custom" or can they be done to a regular block when ordered?
Re: New KB Blocks are moving [Re: sgcuda] #2620193
02/12/19 10:33 AM
02/12/19 10:33 AM
QLD Australia
QLD Australia
sgcuda:
Street blocks come with STD cam & lifters finish machined (including hydraulic oiling).
Race blocks come with +0.250 in raised cam and lifters finish machined. if it's a Race Hemi the cam will be 60mm roller with 2.000 in lifter spacing @ 48 degrees, if it's a Race Wedge the cam will be 55mm roller with 1.800 lifter spacing @ 45 degrees.
All lifters machined for .905 lifters.
See attached spec sheet for details.
Pro blocks allow for custom lifter size, location, angle, and custom cam size.
cheers DB
Darren Beale
Re: New KB Blocks are moving [Re: The Shadow] #2620252
02/12/19 01:47 PM
02/12/19 01:47 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Love the depressurization reliefs at the rear main. Helps running a seal backwards if the oil off the main has somewhere to go other than out the seal lol.
Just a thought. Since the best head available for a mope right now is a predator, maybe consider a 45 degree lifter option for raised cam hemi blocks. The predator is available for a wedge, but is severely limited in capability, due to the valley bolt access cap needed in the top of the intake runner. The bank angle option on the hemi block is the only thing a guy would need to go straight to a pred without incurring additional custom costs.
I built (I think) the first +.5 deck pred. The tall deck let me run a near 7.5 rod, the entire skirt is in the bore, even at 5.125 stroke. Just huge increase in stability, and rod angle with the tall deck. There is room to go to 5.25 stroke if you keep the cam dia down to 54 MM. The lifter bores in mine are 45 with raised cam. I've done raised cam preds with 48 degree lifters, and it's just ugly.
The best heads we have on a big inch motor are all done around 7500rpm as you know, so cam dia beyond 54 really doesn't help IMO. A 2.5 bore tunnel allows for a 54 MM roller bearing (narrow enough for 2" spacing too.), or a 60 bab.
Disclaimer, LOL, As a Mope guy I sincerely appreciate the efforts, and financial risks you guys have borne during this offering. I would still be ecstatic over even a bone stock config aluminum hemi block. THANK YOU GUYS.
Re: New KB Blocks are moving [Re: The Shadow] #2620255
02/12/19 01:55 PM
02/12/19 01:55 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Also adding, since I know NA is becoming a thing of the past.
I understand current trends now are almost entirely bent towards forced induction, negating any real need for large stroke combos. A 9500 RPM 528 on 40 PSI would for sure appreciate some cam dia.
Re: New KB Blocks are moving [Re: Keith Black®] #2620279
02/12/19 03:03 PM
02/12/19 03:03 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
I see there's material there to mount a stock mechanical fuel pump. shruggy
Re: New KB Blocks are moving [Re: The Shadow] #2620295
02/12/19 03:56 PM
02/12/19 03:56 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Nice to see them available. To bad I am not a player for one of these blocks anytime soon. I just keep repairing old beat up KB blocks when I find them.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: New KB Blocks are moving [Re: Keith Black®] #2620323
02/12/19 05:03 PM
02/12/19 05:03 PM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
This is great news
eBay-cdwmotorsports
Re: New KB Blocks are moving [Re: dthemi] #2620566
02/12/19 11:39 PM
02/12/19 11:39 PM
QLD Australia
QLD Australia
thanks Darren, the Pro block accommodates all the things you suggest, I suspect you know the shop that will be doing all our Pro Block machining as they have a ton of experience in exactly this. thanks again for your kind words. Cheers DB
Darren Beale
Re: New KB Blocks are moving [Re: B1MAXX] #2620590
02/13/19 12:33 AM
02/13/19 12:33 AM
NC
440Jim Offline
440Jim  Offline
NC
Originally Posted By B1MAXX
put an INDY block mains up, next to that and I'll take the INDY every time.
KB has 4340 billet main caps, 9/16 main studs and double 1/2 cross bolts and you prefer an indy block with 1/2 mains and cross bolt.
nope..sorry I just felt there was a lingering in the air that the others were obsolete. Maybe I jumped the gun.
As I recall from my 2015? KB block, the main studs are 5/8 thread, and 9/16 shank. Very stout, IMO.
Re: New KB Blocks are moving [Re: 440Jim] #2620597
02/13/19 12:48 AM
02/13/19 12:48 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Long time no post!
Glad you're back.
Kevin
Page 3 of 3 1 2 3
