426 Hemi head weights #2618729
02/08/19 04:42 PM
02/08/19 04:42 PM
IL
8
83hurstguy Offline OP
IL
Does anybody know how much the newer iron MP heads (P4876855) weigh compared to original iron 426 heads (like the 2780559)? I've seen the description of heavier castings for porting + durability but haven't been able to find an actual weight value associated with it.
Thanks in advance!
Re: 426 Hemi head weights [Re: 83hurstguy] #2618901
02/09/19 01:04 AM
02/09/19 01:04 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Bare stock iron is about 65 lbs.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: 426 Hemi head weights [Re: 83hurstguy] #2618911
02/09/19 01:29 AM
02/09/19 01:29 AM
I'm going to guesstimate between 12 and 15 Lbs. from difference between the new bare ones made back in the late 1990s and early 2000 to the original unmolested stock street hemi heads bare after hot tanking them twocents up It may have been even more than that also confused
Re: 426 Hemi head weights [Re: 83hurstguy] #2619032
02/09/19 01:20 PM
02/09/19 01:20 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
From my old notes, my old "66" iron heads assembled,(unported) weighed 62.8lbs.
Re: 426 Hemi head weights [Re: quickd100] #2619083
02/09/19 03:35 PM
02/09/19 03:35 PM
Sweden
MikeN Offline
MikeN  Offline
Sweden
For reference, 1969-70 D4 iron heads, assembled and unported, weigh 61 lbs.
Re: 426 Hemi head weights [Re: 83hurstguy] #2619196
02/09/19 09:33 PM
02/09/19 09:33 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
The last ones they made were very heavy. Sorry I don't have an exact weight.
2011 Drag Pak Challenger
Re: 426 Hemi head weights [Re: 83hurstguy] #2619919
02/11/19 06:19 PM
02/11/19 06:19 PM
IL
8
IL
Thanks for the responses and help. The best I gathered was 5-10 lb/head... if we get our hands on a set we'll weigh them and update the thread.
Re: 426 Hemi head weights [Re: 83hurstguy] #2619926
02/11/19 06:30 PM
02/11/19 06:30 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
To the best of my knowledge, the last ones they made had extra material added for porting........ over and above the earlier MP ones........ that had extra material added for porting.
They sure seem quite a bit heavier than the oe ones that came on production 426’s when you’re moving them around in the shop.
Re: 426 Hemi head weights [Re: 83hurstguy] #2619989
02/11/19 08:45 PM
02/11/19 08:45 PM
hemi-itis Offline
hemi-itis  Offline
Just weighed 69 heads boxed.69.5 lbs.
Re: 426 Hemi head weights [Re: hemi-itis] #2620036
02/11/19 10:53 PM
02/11/19 10:53 PM
The last new Mopar cast iron replacement head I had my hands on had extra metal in it for machining it for dual spark plugs, noticeably heavier than the stock street Hemi iron heads shruggy
Re: 426 Hemi head weights [Re: 83hurstguy] #2620046
02/11/19 11:19 PM
02/11/19 11:19 PM
So. Burlington, Vt.
So. Burlington, Vt.
Oh yeh...... that too.
Re: 426 Hemi head weights [Re: 83hurstguy] #2620052
02/11/19 11:39 PM
02/11/19 11:39 PM
CT
mrrandyj Offline
mrrandyj  Offline
CT
I have a pair of the Mopar Performance heads that I just weighed, 77.8 pounds. I believe these are from at least the 2nd vendor that did them. Maybe Zippy can tell by the castings which ones they are. I also had a pair which I believe were made before these which I will post a picture of below. They are definitely different castings than these are, but had the same part number. Unfortunately, I never weighed those.
Re: 426 Hemi head weights [Re: mrrandyj] #2620055
02/11/19 11:41 PM
02/11/19 11:41 PM
CT
mrrandyj Offline
mrrandyj  Offline
CT
Here is the other pair I had that I never thought to weigh
Re: 426 Hemi head weights [Re: mrrandyj] #2620103
02/12/19 01:11 AM
02/12/19 01:11 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I've been away from the MP world for several years now, but I can remember the M1 suffix was the nicer, thicker/heavier Dalton casting that for a time came without pushrod holes per SS racers request. MP retooled the head at a huge cost but didn't really tell anyone except racers at the time. Being a humble "Tech guy" I found out about it months after the fact. I was told it had extra material for porting but was never told exactly how much extra.
To my understanding the Dalton castings come from those super expensive production style steel tools and as a result they're some of the more consistent parts out there.
The prior generation came from tooling which was normally used for making prototype parts, and was not really intended for long term use. In my discussions with Engineers, the old tooling was often pointed to as the reason for issues with the parts.
Not to say newer castings are totally immune from the issues all cast parts can have, core shift and porosity can and does happen....but the point being better tooling gives consistently better parts and fewer issues. I don't think anyone would disagree the Dalton castings are pretty clean. Also not to say all the older ones have those issues- most are just fine but they do have less material and are just less consistent.
As far as I know, Super stock/the huge round or oval intake ports they use with brazing and tons of material removal pretty much drove the whole thing.
Re: 426 Hemi head weights [Re: 83hurstguy] #2620106
02/12/19 01:12 AM
02/12/19 01:12 AM
A727Tflite Offline
A727Tflite  Offline
A bare stock - M head weighs 72.8 lbs.
Re: 426 Hemi head weights [Re: 83hurstguy] #2620125
02/12/19 02:11 AM
02/12/19 02:11 AM
hemi-itis Offline
hemi-itis  Offline
69 lbs was bare,those are loaded.
Re: 426 Hemi head weights [Re: 83hurstguy] #2620219
02/12/19 12:12 PM
02/12/19 12:12 PM
IL
8
IL
Wow. Great information, thank you to everyone, especially those of you who went above and beyond to help and weigh parts!!! I owe you guys a beer.
We're new to Mopar and slowly figuring this stuff out... thanks again.
