Re: 318 fuel pump installation
[Re: Demonizer]
#261859
03/22/09 10:57 PM
03/22/09 10:57 PM
RapidRobert
(1)prime the carb,start the eng & see if resolved, if not (2)hook gas can to pump inlet, reprime carb, start eng, still no go, the pump or the eccentric & the pump would sure be easier to R&R(& are cheap) even though it just worked before. Things give out at the strangest times but alot of times a pump that is worn just enough that it wont self prime will run OK in daily driving as the lines are not dry.
