Re: Pump Gas Filters
[Re: A/MP]
#2618024
02/06/19 11:06 PM
02/06/19 11:06 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
I use a Mallory canister with cartridge filter before my Mallory 140. Forget what the micron is.
[Re: A/MP]
#2618092
02/07/19 01:33 AM
02/07/19 01:33 AM
Posts: 43,127 Bend,OR USA
Cab_Burge
All the paper fuel filter elements I've heard of are 10 microns, not bigger. Do not use a fuel filter between the pump and the tank that has smaller than 80 Microns filter in it I would and do use a 80+ micron filter between the pump and tank to keep the large particles from going through the pump and a good 10 micron high volume paper element between the electric pump and carb or fuel regulator also
