Pump Gas Filters #2618013
02/06/19 10:41 PM
02/06/19 10:41 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Plumbing the fuel system for my street strip car. Using Mallory 140 pump. Looking for under 50 micron fuel filter that is pump gas safe? Motor is only making 400 HP and using 3/8" fuel line.
Re: Pump Gas Filters [Re: A/MP] #2618024
02/06/19 11:06 PM
02/06/19 11:06 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I use a Mallory canister with cartridge filter before my Mallory 140. Forget what the micron is.
Re: Pump Gas Filters [Re: A/MP] #2618090
02/07/19 01:25 AM
02/07/19 01:25 AM
tucson az
frank Offline
frank  Offline
tucson az
I run Holley 162-550
Re: Pump Gas Filters [Re: A/MP] #2618092
02/07/19 01:33 AM
02/07/19 01:33 AM
All the paper fuel filter elements I've heard of are 10 microns, not bigger.
Do not use a fuel filter between the pump and the tank that has smaller than 80 Microns filter in it tsk
I would and do use a 80+ micron filter between the pump and tank to keep the large particles from going through the pump and a good 10 micron high volume paper element between the electric pump and carb or fuel regulator also up scope
Re: Pump Gas Filters [Re: A/MP] #2618111
02/07/19 03:00 AM
02/07/19 03:00 AM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Anyone like the Fram HP1 with the Wix replacement unit for after the pump?
Re: Pump Gas Filters [Re: A/MP] #2618199
02/07/19 12:28 PM
02/07/19 12:28 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I use a napa 24003. Its actually for a gas pump, I thinks its ten micron and flows a bunch of fuel, and its cheap. aluminum housing with pipe thread at each end. two AN fittings and you instal inline. replacement filters are cheap as well.
https://www.ebay.com/p/Turbo-Fuel-Filter...8655&chn=ps
Re: Pump Gas Filters [Re: A/MP] #2618250
02/07/19 01:59 PM
02/07/19 01:59 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
at 400hp you only need 35gal per flow. I don't know of any 3/8" cellulose that won't do that when put on the pressure side. something like the edelbrock/Russell is 40 micron and cleanable. like Cab said, never put a low micron filter on the suction side of the pump.
Re: Pump Gas Filters [Re: A/MP] #2618375
02/07/19 05:56 PM
02/07/19 05:56 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I like the RobbMC filters that have the sintered brass elements that can be replaced easily or cleaned in a pinch. I run the 10 micron one due to my EFI but he offers different micron ratings.
https://www.robbmcperformance.com/products/filters.html
68 Barracuda Formula S 340
Re: Pump Gas Filters [Re: A/MP] #2618437
02/07/19 08:34 PM
02/07/19 08:34 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Thanks for the info. Never knew that Robb Mc made filters. Using a starter and like the USA small guy manufacturer. I've always filtered my gas prior to filling the cell. Never did the pre-filter. Now its a done deal.Thanks for all the info!
