4 speed adapter plate... #2617946
02/06/19 06:47 PM
02/06/19 06:47 PM
Finally a HUSKER again
Moparnut426 Offline OP
OK guys, hear me out, im haveing a heck of a time finding a big block 4 speed bell housing for a truck that isnt 10 million dollars. I have a mill, I have the tools to make a adapter plate that goes from the 833 pattern on a car bell housing to the wide truck pattern. I was thinking of using 3/8 plate. Im not worried about spline contact, or clutch pivot stuff as I can make all that work with simple tools. Do you guys think Ill need a crank flange spacer to get the clutch and pressure plate correct or is 1/4 or 3/8 not enough to worry about.
Its a farm truck, and a ugly one at that, but I really want to use up some old 383 parts I have laying around.
Re: 4 speed adapter plate... [Re: Moparnut426] #2617950
02/06/19 06:57 PM
02/06/19 06:57 PM
I can even mill the back of the bell housing I have off and then not need a spacer.
Re: 4 speed adapter plate... [Re: Moparnut426] #2617952
02/06/19 06:59 PM
02/06/19 06:59 PM
Buddy brought up a good point, starter issues, so i would have to move flywheel.
Re: 4 speed adapter plate... [Re: Moparnut426] #2617967
02/06/19 07:37 PM
02/06/19 07:37 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
If you also have a welder, I'd say you probably don't even need an adapter. Just weld on more material as needed, then mill off whatever you don't need.
Re: 4 speed adapter plate... [Re: Moparnut426] #2617970
02/06/19 07:47 PM
02/06/19 07:47 PM
I thought about just making an adapter ring to center the truck trans into the car bell if needed, and braze lugs onto the bell housing, but IDK what direction is better. Prolly less screwing around just making the lugs. The bell housing I have is less than stellar as its been repaired already, so Im not messing with anything good to start with.
Re: 4 speed adapter plate... [Re: Moparnut426] #2617975
02/06/19 08:07 PM
02/06/19 08:07 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
How much larger is the truck transmission bolt pattern than the car pattern? Bell housing cast iron?
Re: 4 speed adapter plate... [Re: Moparnut426] #2617980
02/06/19 08:18 PM
02/06/19 08:18 PM
A Red State
SNK-EYZ Online tonguue
SNK-EYZ  Online Tonguue
A Red State
The obvious question is exactly what truck transmission are you trying to bolt up to the big block?
That might help with trying to find a bellhousing.
Re: 4 speed adapter plate... [Re: Moparnut426] #2617991
02/06/19 09:05 PM
02/06/19 09:05 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
How about using a big block scattershield? Got to be easier to machine, weld, etc than cast iron or aluminum.
Re: 4 speed adapter plate... [Re: Moparnut426] #2618036
02/06/19 11:26 PM
02/06/19 11:26 PM
rowin4 Offline
rowin4  Offline
Even a old lLakewood will set you back $1-3 hundred but you could drill /weld whatever onto it with no problem
Re: 4 speed adapter plate... [Re: Moparnut426] #2618196
02/07/19 12:18 PM
02/07/19 12:18 PM
I thought about a old lakewood. A buddy has one but hes gonna use it.
They only made 1 mopar big block 4 speed truck bell housing. its the same old wide 4 pattern from the 62-93 NP435.
they never used the overdrive 833 tranny behind a big block in a pickup that I know of. if they did this wouldnt be a problem as its the same as a car bell housing, so this is the only bell housing ever used behind a big block in a pickup.
Re: 4 speed adapter plate... [Re: Moparnut426] #2618223
02/07/19 01:18 PM
02/07/19 01:18 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The bell is cast so welding is out of the question BUT what about drilling right through and bolting the trans up from behind. If need be you could make 1/8" adapter plates to spread the bolt loads front and back. Bolt the trans to the bell THEN bolt the bell to the motor.
Re: 4 speed adapter plate... [Re: Moparnut426] #2618232
02/07/19 01:24 PM
02/07/19 01:24 PM
I can weld cast iron pretty easily. Just either use Ni rod, or Ill silicon braze it. The tranny is so wide that the face isnt wide enough to accept it so ears will need to be made. Which is why Im thinking the adapter place will be easier.
Re: 4 speed adapter plate... [Re: Moparnut426] #2618249
02/07/19 01:58 PM
02/07/19 01:58 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
It would be easy to make an adapter plate from 3/8" then you could use your mill to take some off the face of the bell to compensate for the adapter plate. You would just need to get some 7/16 countersunk bolts to mount the plate to a standard bell.
Gus beer
64 Plymouth Savoy
Dana 60
Re: 4 speed adapter plate... [Re: Moparnut426] #2618263
02/07/19 02:16 PM
02/07/19 02:16 PM
YUP, thats what Im thinkin ill do. I think 3/8 is over kill, but 1/4 will be fine.
Re: 4 speed adapter plate... [Re: Moparnut426] #2618270
02/07/19 02:37 PM
02/07/19 02:37 PM
rowin4 Offline
rowin4  Offline
If this truck is used for ordinary driving and not like dump truck or pulling heavy equipment I would think the 1/4 or 3/8 plate would work . Setting back that thickness shouldn't affect the pilot bearing or throwout bearing but dimensions should be checked.
Re: 4 speed adapter plate... [Re: rowin4] #2618574
02/08/19 10:05 AM
02/08/19 10:05 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
The new Lakewood(newer part number 15335) accepts the NP435 pattern. It's still expensive, but no fabricating necessary. I've had a few cast big block bells, sure wish I had held on to them.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: 4 speed adapter plate... [Re: Moparnut426] #2618866
02/08/19 10:44 PM
02/08/19 10:44 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Your time must not be worth anything to be willing to do all of that work, those bellhousings usually run $200 from a lot of people.
try a craigslist search via https://www.searchtempest.com/
you can search nationally. Or put out a want ad, someone probably has one on the shelf and would be willing to let it go affordably. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: 4 speed adapter plate... [Re: Moparnut426] #2618908
02/09/19 01:18 AM
02/09/19 01:18 AM
McKinney, TX
badeeds Offline
badeeds  Offline
McKinney, TX
I put an 883 overdrive in a big block truck using a Lakewood bellhousing. All I had to do is machine the bearing retainer down to the center register size of the bellhousing.
Re: 4 speed adapter plate... [Re: badeeds] #2618954
02/09/19 03:57 AM
02/09/19 03:57 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
I will assume you have a post 1968 mechanical clutch version of this pre 69 hydraulic bell?
Re: 4 speed adapter plate... [Re: Moparnut426] #2619002
02/09/19 12:16 PM
02/09/19 12:16 PM
Maryland
twayne24365 Offline
twayne24365  Offline
Maryland
Yea I think he’s talking about the 69+ mechanical linkage big block bell, the 68 and earlier hydraulic big block bells seem much more common, I got lucky and found a mechanical big block bell for my truck
