Re: Rotten roofs
[Re: modelmakerinc]
#2617748
02/06/19 12:33 PM
02/06/19 12:33 PM
Posts: 20,600 in a cattle trailer down by th...
Guitar Jones
Do I ever wish SOMEONE would reproduce those panels! Even if they were partial patch panels it would make life easier. I used a donor roof and cut out what I needed but even it wasn't perfect and man what a PITA it is.
Technically I don't think it's a design flaw as you find that once you get in there you see it's just bare metal, no treatment or paint to speak of.
But while we are at it can We wish for 87-93 wing window seals too?
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
Re: Rotten roofs
[Re: Guitar Jones]
#2617761
02/06/19 12:50 PM
02/06/19 12:50 PM
Posts: 4,696 enfield, CT
ViperDave
enfield, CT
But while we are at it can We wish for 87-93 wing window seals too? I have used the 78-86 wing window seals on 87-93 trucks with no issues.
67 Dart GT Vert 273/904 72 Town & Country 440/727 90 D350 reg cab dually cummins 15 Scat Pack Challenger
Re: Rotten roofs
[Re: ViperDave]
#2617804
02/06/19 01:51 PM
02/06/19 01:51 PM
Guitar Jones
But while we are at it can We wish for 87-93 wing window seals too? I have used the 78-86 wing window seals on 87-93 trucks with no issues. I've heard others say this too but the upper pivot is different and the older wing windows have a metal base on them that the newer ones do not. I don't see how that is going to seal very well and I don't want to waste the money on trying unless I'm sure. Maybe you could post some pics of how well they fit?
Re: Rotten roofs
[Re: modelmakerinc]
#2617934
02/06/19 06:10 PM
02/06/19 06:10 PM
Posts: 2,415 Connecticut
Ron_M
Connecticut
FWIW, it wasn't limited to the full size trucks... Had to do my 93 Dakota as the windshield area was shot.
Common sense is a flower that does not grow in everybody's garden
Re: Rotten roofs
[Re: Guitar Jones]
#2617957
02/06/19 07:07 PM
02/06/19 07:07 PM
Posts: 15,487 Florida
scratchnfotraction
But while we are at it can We wish for 87-93 wing window seals too? I have used the 78-86 wing window seals on 87-93 trucks with no issues. I've heard others say this too but the upper pivot is different and the older wing windows have a metal base on them that the newer ones do not. I don't see how that is going to seal very well and I don't want to waste the money on trying unless I'm sure. Maybe you could post some pics of how well they fit? some glass has 3 holes and some have 2 holes had that mix match on my 85 for a long time till I got a good set of 2 hole wings that matched with good frames. I always thought 3 hole was the early ones but me thinks they are the later ones with no new rubbers?
Re: Rotten roofs
[Re: modelmakerinc]
#2617983
02/06/19 08:25 PM
02/06/19 08:25 PM
Guitar Jones
Yep my 92 and 93 have 3 holes and no metal on the bottom edge.
That metal base has to add at least an 1/8" of thickness to the glass. I can't see how that would possibly seal.
Re: Rotten roofs
[Re: Guitar Jones]
#2618166
02/07/19 10:13 AM
02/07/19 10:13 AM
ViperDave
enfield, CT
heres the seals I did on a 91
Re: Rotten roofs
[Re: modelmakerinc]
#2618182
02/07/19 11:02 AM
02/07/19 11:02 AM
Guitar Jones
Thanks for the pics. Do they really not leak water or wind? Others have said they are still adding coins to the latch handle to tighten them up.
Re: Rotten roofs
[Re: modelmakerinc]
#2618247
02/07/19 01:51 PM
02/07/19 01:51 PM
ViperDave
enfield, CT
they leak a little wind, but I cant hear it or feel it over the cummins.
No rain although my trucks don't sit outside often. new seals don't really combat the coin fix if the latch is worn.
Re: Rotten roofs
[Re: bbtrux]
#2618388
02/07/19 06:26 PM
02/07/19 06:26 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Too bad about that 80's roof. I get your disappointment. Re; Rotten roofs I live the salt = rust part of the country. I have a '76 N a '78. One has surface rust the other is still solid. My ? I used a solid 80's cab from some one here. Now you can go back to the wing window thing.
I have mechanical Aptitude. I can screw up anything.
Re: Rotten roofs
[Re: modelmakerinc]
#2618815
02/08/19 07:25 PM
02/08/19 07:25 PM
Posts: 15,713 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Scratchin' you the man with your trucks, and building. I envy your talent.
The vent windows on my '79 whistle like crazy. My solution is open them, lol. I don't have a/c anyhow, and we don't get much cold weather here. I sure would like to have them quiet though. The main problem with mine seems to be the loose handles more than the rubber. I'm luckY to have a solid truck. I just received new windshield from lmctruck last night. Mine is foggy around edges especially from de-lamination. Maybe when I have old one out I'll have more access to spray underside of roof for protection? Don't the roofs usually rust inside out?
I don't understand why lmctruck doesn't make replacement roofs for the 72-80 at least!!! Maybe it's too expensive to produce? But even front panels seem like they would be extremely profitable!
LET'S ALL START EMAILING LMC WITH REQUESTS TO START MAKING REPLACEMENT ROOFS!!
Facts are stubborn things.
Re: Rotten roofs
[Re: modelmakerinc]
#2618833
02/08/19 08:54 PM
02/08/19 08:54 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I just sent this email to LMC:
LMC truck needs to make replacement roofs, or at least replacement roof panels for the 1972-1980 (or thru 1993 would be better!) Dodge light duty pickups!!!
There's a huge demand. This was a rust prone area, and there are so many trucks out there waiting to be saved, and no donors!!!
Please, please, please!
Here's the email address: CustomerCare@longmotor.net
Re: Rotten roofs
[Re: modelmakerinc]
#2619018
02/09/19 12:50 PM
02/09/19 12:50 PM
Posts: 206 Paducah, KY USA Earth
jcruse64
Exline, while focusing on the Swepties series, has begun producing 72-80 sheet metal, including a bigger floor pan replacement. This last week, on one of the Mopar truck FB pages, someone started a post on a wish-list for body stuff. Kenny, the owner of Exline, posted that he will be coming out with more 72-80 stuff this year, and asked for more suggestions. I told him that complete roof sections seem to be a HUGE request across many FB groups and forums like this one. Maybe he'll try it.
Re: Rotten roofs
[Re: Rhinodart]
#2619219
02/09/19 10:55 PM
02/09/19 10:55 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
How about club cab roofs? I don't see much call for one of those, did they rust the same? I have had a nice roof sale for a few years with no interest. Maybe coming in the "spring of 2019"?
