Can someone double check some final comp numbers #2617089
02/04/19 11:32 PM
02/04/19 11:32 PM
PA.
pittsburghracer Online work OP
"Little"John
pittsburghracer  Online Work OP
"Little"John
PA.
I went from 93 pump gas builds to alcohol type builds so final compression numbers weren't very important to me but I'm almost ready to install my 572 and gotta figure out what race gas I will be needing for this build.
Engine specs
572 cubic inch. 4.500 bore-4.500 stroke
pistons. Nitrous inverted dome -24cc
Cometic head gasket 4.540 bore .060 thick
was told its 15.92cc
B1 head chamber 67.5cc
Using an online calculator I'm getting 107.4cc
11.91 compression.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Can someone double check some final comp numbers [Re: pittsburghracer] #2617098
02/04/19 11:40 PM
02/04/19 11:40 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
I love the oxygenated fuel.. like q16 or something along that line. More than likely you may be able to get away with some C12 depends on the budget you have set for your project
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Can someone double check some final comp numbers [Re: WHITEDART] #2617101
02/04/19 11:42 PM
02/04/19 11:42 PM
PA.
"Little"John
"Little"John
PA.
VERY low budget but I will run one higher grade than needed because of the planned nitrous hit. LOL.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Can someone double check some final comp numbers [Re: pittsburghracer] #2617113
02/04/19 11:56 PM
02/04/19 11:56 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
q16 was the fuel of choice in Ultra for the nitrous car
If you tow the car up and back you will be surprised at how little fuel you actually use. Towing up and back. I use less than a half a gallon per pass.. shakes out to be about $10 a run
Re: Can someone double check some final comp numbers [Re: WHITEDART] #2617117
02/05/19 12:08 AM
02/05/19 12:08 AM
PA.
"Little"John
"Little"John
PA.
I’m a one man show so I will be driving it up and back
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Can someone double check some final comp numbers [Re: pittsburghracer] #2617120
02/05/19 12:24 AM
02/05/19 12:24 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
http://www.diamondracing.net/tools/
This is the best one I've used. I've done the actual math to check it in the past, and it's completely accurate.
Re: Can someone double check some final comp numbers [Re: pittsburghracer] #2617150
02/05/19 01:32 AM
02/05/19 01:32 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Assuming zero deck and 1cc for area above the rings, I get 11.82.
Re: Can someone double check some final comp numbers [Re: pittsburghracer] #2617163
02/05/19 02:11 AM
02/05/19 02:11 AM
baldwinsville new york
a493demon Offline
a493demon  Offline
That's about where i'm at . ( 11.2 or 11.7 I can't remember ) and I run 116
Re: Can someone double check some final comp numbers [Re: a493demon] #2617166
02/05/19 02:23 AM
02/05/19 02:23 AM
PA.
"Little"John
"Little"John
PA.
Appreciate the second set of eyes guys. Heck maybe I can run BP93 pump gas with this combo.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Can someone double check some final comp numbers [Re: pittsburghracer] #2617173
02/05/19 03:39 AM
02/05/19 03:39 AM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
I thought 11.9-1 WAS pump gas smile
Re: Can someone double check some final comp numbers [Re: pittsburghracer] #2617217
02/05/19 10:38 AM
02/05/19 10:38 AM
Northeast Indiana
73DAD Offline
73DAD  Offline
Northeast Indiana
Not enough info to calculate CR. Need to know piston to deck.
If its perfectly zero deck, then 11.92 rounded the nearest hundredth.
Re: Can someone double check some final comp numbers [Re: pittsburghracer] #2617221
02/05/19 10:40 AM
02/05/19 10:40 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Spraying helps pump gas.
I ran in hot rods pump gas drags in 06 with a 12.8:1 engine, and sprayed 200 at it on pump gas, in summer heat. I ran it later with pump, and sprayed 350 at it. When I'd drive it around on really hot days and load the motor at low rpm, it would ping.
I checked the filter regularly when racing it on pump, and spray, and never saw any signs of damaging detonation.
Re: Can someone double check some final comp numbers [Re: Al_Alguire] #2617227
02/05/19 10:57 AM
02/05/19 10:57 AM
PA.
"Little"John
"Little"John
PA.
Heck that’s the highest compression I’ve had in an engine for over 8 years. Lol. Lots of horsepower left on the table with this engine setting it up for nitrous. These were Jason Dixbys rods and pistons from when he switched over to turbo power.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Can someone double check some final comp numbers [Re: pittsburghracer] #2617314
02/05/19 02:45 PM
02/05/19 02:45 PM
Cheswick, PA
Bob_Spelic Offline
Bob_Spelic  Offline
Cheswick, PA
at zero deck, I get 11.87. at .020 in the hole I get 11.37 on my home brew spreadsheet calculator.
bob
Re: Can someone double check some final comp numbers [Re: Bob_Spelic] #2617321
02/05/19 02:56 PM
02/05/19 02:56 PM
PA.
"Little"John
"Little"John
PA.
bob
Thanks guys. It’s zero deck.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Can someone double check some final comp numbers [Re: pittsburghracer] #2617333
02/05/19 03:04 PM
02/05/19 03:04 PM
PA.
"Little"John
"Little"John
PA.
It probably won't be a very competitive combo but I will get my feet wet with nitrous. Someone said I was scared to go fast so I should be ok going a little slower. LOL.
Untitled by John Cadamore, on Flickr
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Can someone double check some final comp numbers [Re: pittsburghracer] #2617354
02/05/19 03:54 PM
02/05/19 03:54 PM
Washington
madscientist Offline
Washington
Is that the CR you were shooting for? If so, golden. If not...bummer.
Re: Can someone double check some final comp numbers [Re: madscientist] #2617378
02/05/19 04:57 PM
02/05/19 04:57 PM
PA.
"Little"John
"Little"John
PA.
I honestly didn’t have a target in mind. I had this engine together with a set of Wiseco pistons as a NA combo. I talked to Vic at Wisco and he recommended only hitting them with 200-250. I had bought a set of nitrous pistons from Jason Dixby when he was switching to turbo power so I used those pistons in this build. I have a Sledgehammer plate system that is good for a 300-700 hit
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Can someone double check some final comp numbers [Re: pittsburghracer] #2618081
02/07/19 01:11 AM
02/07/19 01:11 AM
NY
B1duster Offline
B1duster  Offline
NY
At zero I get 11.77 on Diamond Pistons calculator
Re: Can someone double check some final comp numbers [Re: pittsburghracer] #2618872
02/08/19 11:09 PM
02/08/19 11:09 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
What cam is in it ? I ask because a nitrous grind that opens the exh really early, would benefit from more compression. Also how much nitrous are you going to use ? Depending on the cam, it might want 13 or more. You know what your doing with an engine, so you'll learn through testing . Also are the chambers softened on your heads ?
....BAD A$$ STREET CAR.....
