Re: Hemi Valve Spring Compressor
[Re: 71birdJ68]
#2616643
02/03/19 11:03 PM
02/03/19 11:03 PM
Posts: 4,457 Washington
madscientist
Washington
Doesn't LSM make something?
[Re: 71birdJ68]
#2616673
02/04/19 12:45 AM
02/04/19 12:45 AM
madscientist
Washington
lsmproducts.com I just did a quick check and the do have a hemi tool but it's not for the two shaft system. If you have the individual shaft system it works. If you have the two shaft system you may want to call them and see what they may have.
[Re: 71birdJ68]
#2616707
02/04/19 02:10 AM
02/04/19 02:10 AM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
I made my crude tool 20 years ago.The hard part is the rocker must be removed.I used compressed air to hold the valve up.
[Re: 71birdJ68]
#2616773
02/04/19 09:50 AM
02/04/19 09:50 AM
Posts: 10,124 A Red State
SNK-EYZ
A Red State
It's from Detroit Tools.
From one of the threads in the link.
"It's called the 426HemiVSR. I love it. You can order it directly from Detroit Tools Contact Mike Pollock at 1-313-942-2816"
When I was trying to buy one in 2014 they wouldn't return my calls at that phone number.
I don't know if they're still in business.
Mancini Racing used to sell them, but took them off their website since 2014 (they were out of stock at that time).
I bought one from a member here back in 2014, but have since sold it to a friend after I traded off my car that had the Gen 2 Hemi in it.
[Re: 71birdJ68]
#2616793
02/04/19 12:00 PM
02/04/19 12:00 PM
Posts: 11,993 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I know a lot of guys (maybe most) use air to hold the valves closed, but I just can't help worrying about it bleeding off. I have always used a piece of rope in the cylinder. Rope seems somewhat more dependable.
Master, again and still
[Re: DaveRS23]
#2616882
02/04/19 02:47 PM
02/04/19 02:47 PM
Posts: 8,018 Tulsa OK
Bad340fish
Tulsa OK
I know a lot of guys (maybe most) use air to hold the valves closed, but I just can't help worrying about it bleeding off. I have always used a piece of rope in the cylinder. Rope seems somewhat more dependable. I always put the piston up top when doing this, that way if you lose air you don't lose the valve. I know a guy that actually had the rope method get tangled up and it caused him real hell trying to avoid tearing the motor down to get it out.
68 Barracuda Formula S 340
[Re: 71birdJ68]
#2616889
02/04/19 03:00 PM
02/04/19 03:00 PM
Posts: 19,355 Las Vegas
Al_Alguire
Las Vegas
Check with Buxton Engineering, they make THE best on head compressor out there. LSM also makes very nice stuff
[Re: Bad340fish]
#2617040
02/04/19 09:36 PM
02/04/19 09:36 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I know a lot of guys (maybe most) use air to hold the valves closed, but I just can't help worrying about it bleeding off. I have always used a piece of rope in the cylinder. Rope seems somewhat more dependable. I always put the piston up top when doing this, that way if you lose air you don't lose the valve. I know a guy that actually had the rope method get tangled up and it caused him real hell trying to avoid tearing the motor down to get it out. Yeah, Murphy in action. Nothing is fool proof. But I had never seen or heard of a problem with the rope.......until now. I have, however, seen problems with air leaking off and letting the valve get too far into the cylinder.
[Re: 71birdJ68]
#2617042
02/04/19 09:38 PM
02/04/19 09:38 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Would borrowing one do it? Or do you need one permanently?
