Re: challenger shaker hood
[Re: KillerBee]
#2616008
02/02/19 03:33 PM
02/02/19 03:33 PM
Posts: 1,174 Woodbridge
Tommy The Chryco
Woodbridge
I don't think so. Try AMD they may have a different listing then the Cuda.
Fight the Good Fight- Elastomeric Bumpers and The Better "Shaker kits"
[Re: KillerBee]
#2616029
02/02/19 04:47 PM
02/02/19 04:47 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Is anyone making a good fitting repop Challenger shaker trim ring? I'll assume you have an original hood? ...the AMD Challenger ring is the nicest/closest original looking one out there on the market compared to the others, but fit is going to be a 50/50 shot, might want to also consider the one Resto Rick (if he still carries it?) has as well, but IIRC the mounting studs are exposed (drilled/tapped) thru the top surface and will need to be addressed, the SnoBar/Shakerhood.com ring is the same last I seen, the AMD studs are cast into the ring, I think whomever's ring you buy the fit will be compromised by either size opening gap/stud layout and or contours... personally your better off buying an AMD hood complete, or looking for an original ring if fitting it to an original hood, pick your poison? Mike
[Re: 340clone]
#2616710
02/04/19 02:15 AM
02/04/19 02:15 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Not to get off course too much here, but is anyone still selling complete shaker hood set-ups, including the complete bubble unit? If you want to throw some coin out, Sixpack Performance in New Mexico may still have so-called "complete kits", IMHO your better off sourcing the parts thru Tommy the Chryco and AMD
