Re: Gen II hemi block P5160151AC
[Re: iapco103]
#2615504
02/01/19 11:03 AM
02/01/19 11:03 AM
Posts: 941 Texas, USA
ChrgrCuda
Texas, USA
Almost worth pulling the trigger on if I knew who was casting them. Says they ship tomorrow on Jegs.
68 Cuda Notchback [Email]10.86@120[/Email]
69 Charger R/T 440/505
2009 Challenger SRT8
[Re: rickseeman]
#2615556
02/01/19 01:02 PM
02/01/19 01:02 PM
Posts: 350 Mequon, WI
gzig5
Mequon, WI
I like their price but it's hard buying something from a business without a phone. RockAuto is the same, no phone, all comms by email. But they are well established and you're usually not dropping $3500 on an order with them.
[Re: jughed]
#2615583
02/01/19 02:24 PM
02/01/19 02:24 PM
Posts: 1,695 central il.
second 70
central il.
[quote=jughed]This site has them listed for nearly $600 less. https://www.moparamerica.com/oem-parts/mopar-block-bare-block-p5160151acThey and Jegs also have another Hemi block listed. P5160149AC. It's slightly pricier, but no bore size, or overview are given. Anyone know the difference Mike I'm guessing the 149 is finish bored.If you can find one P1560150AC is a 4.5 bore. In the questions on the 149 they say it is an OEM block and not mega. The 151 they say is current production run and a standard cast iron block. #350. No problem Jegs will price match the cheaper listing too. Mike
[Re: ChrgrCuda]
#2615614
02/01/19 03:36 PM
02/01/19 03:36 PM
Posts: 17,801 S.E. Michigan
ZIPPY
S.E. Michigan
I haven't seen this batch.....take with a grain of salt
The last batch we saw back in August was Dalton Foundry (same as previous/going back to 2008 when the "world" block came out) out of IN, and a newer machine shop JNB out of Fowlerville MI. It appeared to many to match the mp mgt story that old castings were waiting to be machined, and some folks commented the castings appeared to have sat for a time.
MP never required a traceable casting date marked on the block (only machining dates are documented), so no telling.
best guess: Most likely the same supply chain as last August...however to look into it, I would need access to the supplier codes on the label + would need to see the foundry mark on a recently purchased block to confirm.
A batch of 10 showing up at Jegs is a good sign they're probably running them again for real.
Rich H.
Esse Quam Videri
[Re: iapco103]
#2615658
02/01/19 05:55 PM
02/01/19 05:55 PM
Posts: 14,479 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
On the Jegs website, it shows an expected delivery date of 2/28/19 for that part number.
It’s doesnt show it as in stock.
My guess is....... if they got a delivery of 10, they’d be gone in a few days.
[Re: ZIPPY]
#2615660
02/01/19 05:57 PM
02/01/19 05:57 PM
Posts: 1,263 New York, USA
Chargerfan68
New York, USA
Do you mean only the mp world blocks only? I think my mp mega block (pre world) has a casting date on it. Circa 2006. Not 100% sure , but i believe it is a casting date.
[Re: iapco103]
#2615662
02/01/19 06:00 PM
02/01/19 06:00 PM
Posts: 4,540 Motor City
6PKRTSE
Motor City
On Summit, Jegs or many other websites ifor it doesn't say the same ship day as the date you are ordering that usually means it is not in stock and has to be ordered by them from the manufacturer.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Chargerfan68]
#2615663
02/01/19 06:08 PM
02/01/19 06:08 PM
ZIPPY
S.E. Michigan
Do you mean only the mp world blocks only? I think my mp mega block (pre world) has a casting date on it. Circa 2006. Not 100% sure , but i believe it is a casting date. Yep, that's what I meant....Post '08 World Style has no casting date. The date etched into the front is just a machining date. Pre-World water and mega was a whole other setup, everything was different.
Rich H.
Esse Quam Videri
[Re: gsmopar]
#2615763
02/01/19 11:13 PM
02/01/19 11:13 PM
Posts: 3,020 NY
B1duster
NY
Jeg's Link Mopar Performance's 426 Hemi Block features a 10.275 in. deck height, 4.240 in. bore, and a standard 4.800 in. bore spacing. With a maximum stroke clearance of 4.500 in. out of the box and a maximum bore of 4.560 in., you can take the Mopar Performance 426 Hemi Block all the way up to 588 cubic inches.
Mopar Performance's 426 Hemi Block crankcase will accept an up to 0.250 in. more stroke with additional machining, allowing up to 620 cubic inches. That's over 10 liters of displacement!
Features:
10.275 in. Deck Height 4.240 in. Bore (up to 4.560 in. with additional machining) 4.500 in. Maximum Stroke (up to 4.750 in. with additional machining) Up to 10.2L of Displacement
I’m sure it’s a misprint but it says 10.275 deck height
[Re: iapco103]
#2616453
02/03/19 03:28 PM
02/03/19 03:28 PM
fast68plymouth
So. Burlington, Vt.
I wonder if they actually had them or not.
If they did, I’m not at all surprised they sold out quickly.
