Mystery Bracket
#2614874
01/31/19 01:37 AM
01/31/19 01:37 AM
Posts: 367 Akron, Ohio
VegasCharger
Akron, Ohio
Got this "seagull" looking mystery bracket and I'm uncertain of it's orientation. I know it's Mopar blood lol. Is it some sort of A/C line hold down? It measures 2" in length. Thanks in advance.
Re: Mystery Bracket
[Re: NANKET]
#2614922
01/31/19 08:51 AM
01/31/19 08:51 AM
VegasCharger
Akron, Ohio
Master cylinder lid clamp. Manual brake with bolt on lid. That center square has been added. Thanks NANKET! So the center square (which is a threaded nut upon a closer look) was added on? Well that makes sense if the brake master clamp bolt catches the threads on the reservoir, there would be NO need for the clamp to have threads for the bolt. Maybe someone was making sure that the clamp wouldn't come loose by having two thread sources for the bolt?? Anyway thanks again, what time era/make/model/platform are we talking here?
Re: Mystery Bracket
[Re: VegasCharger]
#2614997
01/31/19 12:47 PM
01/31/19 12:47 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
the center square nut seems was born there, not added. ( not saying it is, but just it looks like )
Re: Mystery Bracket
[Re: 71birdJ68]
#2615101
01/31/19 03:15 PM
01/31/19 03:15 PM
Posts: 19,305 north of coder
moparx
this is from deep inside my old, foggy brain, so keep that fact in "mind" [get it ? ] anyway, i somehow "think" there was a shoulder on the master cylinder hold down bolt that allowed it to spin and tighten the lid on the master cylinder, and when the lid was removed for servicing, the bolt and retainer stayed together. this made the bolt hard to loose, and insured the correct length bolt was always used with the hold down. at one time, i had a couple of those style masters around, and they may still be here, but i haven't seen them for years and years. and if i are "rong", well, just chalk it up to a blabbering old geezer.
Re: Mystery Bracket
[Re: topside]
#2615747
02/01/19 10:15 PM
02/01/19 10:15 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Definitely not for a master cylinder. Want to agree with the truck jack deal, but I seem to remember a wing nut type deal there... I'd have to go look, but it's too cold and dark for that right now.
I have mechanical Aptitude. I can screw up anything.
Re: Mystery Bracket
[Re: VegasCharger]
#2618085
02/07/19 01:19 AM
02/07/19 01:19 AM
VegasCharger
Akron, Ohio
Thanks for all of the replies! To clear things up on whether the square nut was added on or was on there originally, I went ahead and cleaned off the rust and took close up pics. As you can see in the pics below it sure does look like it was there originally. So the debate of it being on there is correct. So brake master cylinder clamp???
Re: Mystery Bracket
[Re: Jwilli500]
#2618215
02/07/19 01:05 PM
02/07/19 01:05 PM
Posts: 526 Marilla, New York
RalleyA12
Marilla, New York
Maybe to hold down a folding handle for a jack? (Think Pickup) Try asking over at the truck forum, I remember a bracket that held the jack on my 1978 Dodge pickup that looked something like that.
