Page 3 of 3 1 2 3
Re: Can you make a Dominator carb streetable? [Re: GY3] #2614004
01/29/19 01:33 PM
01/29/19 01:33 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The biggest disasters of Doms on the street, is when they're on small cam engines with tons of vac, that they don't belong on in the first place.
Exactly.
Can they be made to work on that application?
Sure....... just realize you’re way outside the box for what the carb was designed for........ so expect to have to mess with it.
Re: Can you make a Dominator carb streetable? [Re: fast68plymouth] #2614122
01/29/19 04:25 PM
01/29/19 04:25 PM
Canada
RobR Offline
RobR  Offline
Canada
My DaVinci dom (spider) runs like a champ..I drove it every where,never a problem...
Rob
Re: Can you make a Dominator carb streetable? [Re: GY3] #2614325
01/29/19 10:54 PM
01/29/19 10:54 PM
Mark Whitener Offline
A Dominator can be made to run very well on the street, even with a small cam. The big issue is what casting is it, when was it made, and where and how big the t-slots ended up. The best to use are the early non HP bodies that had the smallest t-slots. Also any that BLP put t-slot plugs in. And of course either an APD or BLP billet body. Some of the HP castings had slots in the wrong place or too big, they can be more difficult to get dialed in. Look for a casting with slots under .026 wide, and with the bottom of the slot at the top of a completely closed throttle blade. And make sure it has not been filed on, it is required on rare cases but makes it tough to get right at low speeds.
Mark Whitener
[url=www.racingfuelsystems.com[/url]
Re: Can you make a Dominator carb streetable? [Re: GY3] #2614420
01/30/19 02:12 AM
01/30/19 02:12 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Drilling holes in the blades help you stay off the transfers when they've been molested.
Re: Can you make a Dominator carb streetable? [Re: dthemi] #2614459
01/30/19 06:32 AM
01/30/19 06:32 AM
Sydney,Australia
tex013 Online content
tex013  Online Content
Sydney,Australia
That is my next move , just cannot get blades/rpm right . Frong ok , rear too far open
But dont want to play too much whilst waiting for my new 505,currently have 440
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Can you make a Dominator carb streetable? [Re: tex013] #2614636
01/30/19 04:49 PM
01/30/19 04:49 PM
I would, and do up restrict the idle fuel feed and transition fuel feed in the main body before drilling the throttle blades to lean the mixture out scope wrench twocents
Page 3 of 3 1 2 3
