Re: Gen 2 Hemi Bracket Motor?
[Re: quickd100]
#2614316
01/29/19 10:45 PM
01/29/19 10:45 PM
Posts: 12,408 Taxes & Virus's R-US, NY
Dragula
Don't shoot me, but don't the millenium heads require a sheet metal intake? I don't know of any cast intakes that fit those, but I could be wrong.
I run the big runner Indy single 4 intake on my 605....I like it. Its fairly light, has huge runners, and fuel distribution is not bad at all.
The Indy Hemi tunnel ram suffers from a small plenum. A lot of people that do run them ad a big spacer to help. Even with efi on my old one, I did the same thing and it helped a bunch.
If I had your parts, I would build as many cubes as possible, and go with the RBRE rocker arms in a high ratio to help the cam. From there, compression is about all you have left to pick.
[Re: 604 Hemi GTX]
#2614326
01/29/19 10:55 PM
01/29/19 10:55 PM
Posts: 10,043 MN
JERICOGTX
MN
No Gen2 HEMI should run a single 4Bbl carb. It's just wrong. LOL.
69 GTX
68 Road Runner
[Re: 604 Hemi GTX]
#2614346
01/29/19 11:24 PM
01/29/19 11:24 PM
Posts: 10,043 MN
JERICOGTX
MN
Alright alright I’ll get a sheet metal manifold built Lol
Kevin Just giving you a hard time Kevin. Bought any new parts for the project? Jeff
69 GTX
68 Road Runner
[Re: 604 Hemi GTX]
#2614353
01/29/19 11:46 PM
01/29/19 11:46 PM
Posts: 10,043 MN
JERICOGTX
MN
I have a local guy do my block work. He's a one man shop, and swamped with work.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2614381
01/30/19 12:30 AM
01/30/19 12:30 AM
Dragula
No Gen2 HEMI should run a single 4Bbl carb. It's just wrong. LOL. I know,,,,Lend me an Eddy single plane dual quad with a pair og 800cfm Thunder series carbs and I will try it...
