overdrive unit #2613846
01/29/19 02:39 AM
01/29/19 02:39 AM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
seems i was told that the od unit was the same on a A500 and a A518???,hyd controled not ecm controled>??
my ladder of success is missing some rungs
Re: overdrive unit [Re: rhad] #2613881
01/29/19 05:21 AM
01/29/19 05:21 AM
Guitar Jones Offline
Sort of. The number of clutches may be different but as long as it's not a diesel or V10 they will interchange.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: overdrive unit [Re: rhad] #2614126
01/29/19 04:38 PM
01/29/19 04:38 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The pre-'96 OD unit still has a mechanical governor inside so it is considered a hydraulic-controlled unit even though it needs an electric signal to engage the OD.
Re: overdrive unit [Re: rhad] #2614275
01/29/19 09:35 PM
01/29/19 09:35 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
i heard they were all the same....
Re: overdrive unit [Re: rhad] #2614299
01/29/19 10:07 PM
01/29/19 10:07 PM
A727Tflite Offline
A727Tflite  Offline
Not very clear on what you are asking.
Two variants for control regarding the 1/2, 2/3 shifts.
RH uses a typical governor while the RE uses a governor pressure transducer and duty cycle solenoid to generate gov. pressure.
Both the RH and RE use electronic controls to achieve the 3/4 shift.
Re: overdrive unit [Re: rhad] #2614348
01/29/19 11:31 PM
01/29/19 11:31 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I think he wants to know if an A500 OD unit will interchange with an A518.
Kevin
Re: overdrive unit [Re: rhad] #2614377
01/30/19 12:22 AM
01/30/19 12:22 AM
A727Tflite Offline
A727Tflite  Offline
The back of all overdrive transmissions are the same.
There are two styles of overdrive piston retainer - one for the RE and one for the RH.
