A-518 and Big Block Tranny #2613513
01/28/19 02:32 PM
01/28/19 02:32 PM
Missouri
3
3_RTs Offline OP
3_RTs  Offline OP
Missouri
I would like to use the A-518 overdrive tranny in my B-body with my 440. I have read the articles on what to do and how its been done, but here is my question, Can the internal parts of a 518 be put inside a big block tranny case or is it totally different? I've heard the 518 described as a 727 with an overdrive added. Is there more to it? I'm not fond of using an adapter plate or cutting and swapping bellhousings from one to the other.
Re: A-518 and Big Block Tranny [Re: 3_RTs] #2613521
01/28/19 02:45 PM
01/28/19 02:45 PM
moparx Offline
moparx  Offline
the OD case is specific to the A518, so you can't swap anything over from the OD part of the unit to a standard 727 case. the ONLY option[s] you have is the ultra bell, or a swap adapter plate.
from the OD part forward, however, the internal parts are interchangeable, but the case has internal passages where the tailshaft/OD unit bolts up, preventing just bolting up the OD to the 727 case, and getting it to work.
myself, i'm going for an ultra bell. [as soon as i score an A518 core]
beer
Re: A-518 and Big Block Tranny [Re: moparx] #2613525
01/28/19 02:52 PM
01/28/19 02:52 PM
Missouri
3
3_RTs Offline OP
3_RTs  Offline OP
Missouri
Thank you, Moparx. I will probably do the Ultra Bell also.
Re: A-518 and Big Block Tranny [Re: 3_RTs] #2613609
01/28/19 06:11 PM
01/28/19 06:11 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Lots of guys have done it here. I did two years ago with advice from this forum. Still running good behind a stroked 512.
