front knuckles the same? #2613392
01/28/19 08:54 AM
01/28/19 08:54 AM
indy
70moparmike Offline OP
indy
69 gtx again, are the left and right knuckles the same? drum brakes. i am installing wilwood front brakes and they say you have to use front drum knuckles. thanks moparts!
Re: front knuckles the same? [Re: 70moparmike] #2613394
01/28/19 09:12 AM
01/28/19 09:12 AM
Mass
charge70 Offline
charge70  Offline
Mass
Yes,they are the same for each side.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: front knuckles the same? [Re: 70moparmike] #2613903
01/29/19 08:41 AM
01/29/19 08:41 AM
indy
indy
thank you charge 70
