Re: Finish line rules
[Re: mills.mopar]
#2613364
01/28/19 03:31 AM
01/28/19 03:31 AM
Posts: 1,099 Massillon, Ohio
cudatom
Massillon, Ohio
Every track that I have raced at for the past 40 yrs has the same view on excessive braking. One warning and then DQ. Excessive braking is hitting the brakes hard enough to smoke the tires. Nothing really vaugue about it.
Ok
[Re: cudatom]
#2613378
01/28/19 04:31 AM
01/28/19 04:31 AM
Posts: 252 southeast ky
mills.mopar
southeast ky
Specifically I'm asking about IHRA tracks. I should have stated that in the first post. I've never been able to find a specific rule on this, that's the whole reason for me asking the original question...
Jeff
If you love it lube it
68 dart 37 dodge coupe 71 challenger
[Re: mills.mopar]
#2613441
01/28/19 12:01 PM
01/28/19 12:01 PM
Posts: 4,206 New York
polyspheric
New York
A "rule for excessive braking"? The rule is: someone important doesn't like it. That not a rule, that's an opinion.
The entire point of having rules is NOT to rely on someone's opinion.
Boffin Emeritus
[Re: mills.mopar]
#2613454
01/28/19 12:25 PM
01/28/19 12:25 PM
Posts: 2,475 SW Ohio
cgall
SW Ohio
Excessive braking is a universal rule, I would doubt any track would say they allow it. Some tracks have their own set of rules, such as a visible tail light, courtesy staging, no beer in the pits, and the like. There are 4 IHRA tracks in KY, Beacon, I-64, London and Clay City. Go on their website or call them to see if they have any rules in particular. I tend to stay North of the Ohio river, as some of those tracks still have single Armco guardrails and the tech inspection consists of handing in your tech card to a teenage girl in the tower.
[Re: cgall]
#2613466
01/28/19 12:57 PM
01/28/19 12:57 PM
mills.mopar
southeast ky
Cgall. I'll agree with you 100% on the tech inspection down here! I used to race at Byron and RT 66, it's a whole other world down here as far as tech inspection goes... I don't understand it.
Jeff
[Re: mills.mopar]
#2613469
01/28/19 01:02 PM
01/28/19 01:02 PM
polyspheric
New York
Remind me not use use logic in these remarks, doesn't seem to have any effect.
Boffin Emeritus
[Re: polyspheric]
#2613474
01/28/19 01:15 PM
01/28/19 01:15 PM
Posts: 3,077 Michigan
A727Tflite
Remind me not use use logic in these remarks, doesn't seem to have any effect. What logic was used and what was ignored?
[Re: A727Tflite]
#2613524
01/28/19 02:52 PM
01/28/19 02:52 PM
Posts: 11,578 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Remind me not use use logic in these remarks, doesn't seem to have any effect. What logic was used and what was ignored? I get it. I've seen the "rule" enforced differently even at the national event level, depending on who the offender was. Tire smoke or no tire smoke? Crossed up or not? Under control or not? It's a judgement call, probably depending on how long it's been since someone slid the tires and hit the wall.
[Re: mills.mopar]
#2613590
01/28/19 05:02 PM
01/28/19 05:02 PM
cudatom
Massillon, Ohio
Jeff That was both IHRA, NHRA and outlaw tracks.
Ok
[Re: bigdad]
#2613603
01/28/19 05:46 PM
01/28/19 05:46 PM
Posts: 1,826 South Bend
John Brown
South Bend
I believe it was the 68 or 69 NHRA Nationals that Judy Lilly blew out both front tires because of locking up the brakes in the lights trying to keep from breaking out. Nothing new here.
[Re: DoubleD]
#2613621
01/28/19 06:39 PM
01/28/19 06:39 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
Its a safety issue - if you are smoking the tires with excessive braking then - quite frankly you need to leave before you hurt yourself or somebody else. It was happening at Norwalk in the slower brackets to the point guys were spinning out at top-end playing the stripe. Scrubbing a little speed off is one thing but locking up your front tires is just plain stupid! I agree 100%. Nothing wrong with scrubbing a bit but most of that can be done with your right foot. Also ...if you have to hold a tenth to win a race I would suggest buying my car.....it runs the number.
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: mills.mopar]
#2614252
01/29/19 08:43 PM
01/29/19 08:43 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
If being able to scrub a little speed is so much more important than a couple MPH why not just run a little wider tire so you can brake without locking em up.
