Re: Cylinder scratches [Re: ] #2613432
01/28/19 11:36 AM
01/28/19 11:36 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
To me it looks like just about every old TRW heavy slug - stock rodded engine after a few years of running! - the skirts on those pistons always seem to have had a funky edge on them from the forging process - we used to dress them with a honing stone. If it has good ring seal now run it if not - give it a quick dingle ball hone hone and run it - those pistons are pretty forgiving when it comes to clearence as long as its not too tight.
Re: Cylinder scratches [Re: Cab_Burge] #2613674
01/28/19 08:35 PM
01/28/19 08:35 PM
69cornetr/t
69cornetr/t
This for everyone who wanted to know.
Talked to my machinist, who's also a drag racer take a piston out look at it and ,"if it's not black death don't worry about it" which is the skirt gaulding the cylinder wall leaving black lines on the piston skirt.clean the cylinder wall with WD40
So I'm good to go.
Re: Cylinder scratches [Re: ] #2613698
01/28/19 09:22 PM
01/28/19 09:22 PM
Washington
madscientist Offline
Washington
So I'm good to go.
If they are only black on the back side i.e. the non thrust side that's from running a plug that's too hot. I've seen it many times. Back siding is usually the wrong plug.
Re: Cylinder scratches [Re: ] #2613708
01/28/19 09:53 PM
01/28/19 09:53 PM
69cornetr/t
69cornetr/t
Really? No black,but When you say back side do you mean toward the cam and why would a hot plug cause that? Running lean?
Re: Cylinder scratches [Re: ] #2613843
01/29/19 02:30 AM
01/29/19 02:30 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Run it. The scratches are what they are, and were there when you ran it last. That little bit of surface rust will hurt nothing. That'll get wiped off in an instant. Then if there is any tiny pits, they'll just hold oil.
Also those are nothing in terms of scratches from what i see in the pictures.
