Re: cross ram physics
[Re: Twostick]
#2612998
01/27/19 12:17 PM
01/27/19 12:17 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
How many bolts do 1961 413 valve covers have? Stock 440 has 6, the early 413's had 4 but I'm not sure when they changed.
Kevin 4 bolts.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: Handygun]
#2613046
01/27/19 02:16 PM
01/27/19 02:16 PM
Posts: 693 Dunnellon, FL
longram60
Dunnellon, FL
Long rams on my '60 Plymouth. It behaves well on the street, runs high 11's in the quarter. Mine are the 'short' rams. Carbs are Carter Competition 500CFM. Race set-up: Street set-up:
1979 AMC Spirit, NHRA Q/SA
[Re: longram60]
#2613053
01/27/19 02:40 PM
01/27/19 02:40 PM
Posts: 19,687 north of coder
moparx
my rams are the long version, and previous owners chopped out the four hole dividers at the carb bases. also, the heat chambers under the carbs are rotted through. so since repairs are needed, is it wise to cut the tubes and remove the dividers, effectively making them short rams ? if so, would cutting the dividers a touch shorter make the RPM usable to around 6k ? has anyone done other mods to these that work out good ? i'm also planning on trying a pair of thermoquads. this is for my humpback with projected weight of 2500 or less.
[Re: BSB67]
#2613076
01/27/19 03:50 PM
01/27/19 03:50 PM
Posts: 2,885 Pattison Texas
CSK
Pattison Texas
I bet those same XR lobes on a 113° - 114° LSA, and loosening up the lash would clean up the idle a lot, and put power in the motor too. Looks like lash adjustment is no easy job. Agree on the wide LSA this is an OLD Harley engine I built, this is a 94 inch Harley, very old design with heads I ported on the large side for cid, it is also EFI, the blue run on the dyno is with a 8 inch long individual runner length, very gutless down low, the red line is with 22 inch runners, everything else is the same, this is only for a 2 cyl, X the results by 4 for an 8 cyl
[Re: Handygun]
#2614045
01/29/19 02:45 PM
01/29/19 02:45 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The “short” and “long” versions are actually about the same overall length, right?
The term is really referring to the length of the divider wall.......yes?
How much difference in length of the divider wall between the two?
I admire you guys who are willing to mess with that stuff...... but it’s way outside of my KISS philosophy.
[Re: fast68plymouth]
#2614056
01/29/19 03:03 PM
01/29/19 03:03 PM
moparx
question #1 and #2, yes. the third question, i'm not sure. my one buddy always says : "why keep it simple when you can complicate the sh!t out of it ?" also, as you probably know by now, i kind of like to try things that are uncommon, or against the grain of proven knowledge. and i use what i have because of budget and the "what happens if" mentality i have. having the instructions on the long to short conversion, and being a retired machinist, this looks like i will tackle this job. my intake setup is complete except carbs, and has been hacked on before i got it. it also needs repair on the exhaust heat plenums, so it needs some re-work regardless. it looks good, and i have zero invested ! sooo......
[Re: moparx]
#2614153
01/29/19 05:22 PM
01/29/19 05:22 PM
dogdays
The "ram effect" depends on the speed of sound so engine size shouldn't affect it. I'd suggest using the factory cam LSA and intake CL and go symmetrically bigger on the lobes.
There is a TON of wall friction and that depends entirely on the length of the divided section and the overall length. This is like pipe friction, which increases as the square of the velocity. Going from 413 to 440 increases the velocity 6.54%, pipe friction increases by 13.5% I think with the bigger engine the power curve to the torque peak increases and then after the torque peak it drops rather dramatically.
For a 500 inch engine it'd be like breathing through a straw.
R.
[Re: Handygun]
#2614237
01/29/19 08:09 PM
01/29/19 08:09 PM
Posts: 4,213 New York
polyspheric
New York
IIRC the original tuned runner length is 30"? Deduct 10.5" for the un-cut remainder as per the instructions: 19.5" is now siamese. I have no idea how any math works out here, but Chrysler almost certainly did multiple back-to-back tests before releasing the mod. The question: how dependent on the original (mild) cam specs is the new 10.5" length, and would you want to second-guess it?
Boffin Emeritus
[Re: quickd100]
#2614560
01/30/19 01:42 PM
01/30/19 01:42 PM
moparx
thank you for that link ! i have never seen that before. looks like a relatively easy task to do. would you suggest repairing the 4 holes at the carb pad, or leave the pad open as it is now ? Personally, if I liked it simple the bowtie brigade would suffice. I m one of those guys that have always been drawn towards the quirky stuff. I've also wondered how and why something works. The worst thing someone can say to me is you can't do that or it will never work. I guess I'm a bit stubborn and bullheaded, more often than not they are correct. But, once in awhile I prove them wrong and that's very satisfying. are you perhaps, my brother from another mother ? exactly my way of thinking ! around here, i'm a misfit with my brand loyalty. as always, most are brand x and y, so i get busted on constantly. plus, all of my wounds are self inflicted.
