Re: Engine Run Stand [Re: mrrandyj] #2612433
01/26/19 04:03 AM
01/26/19 04:03 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Originally Posted By mrrandyj
I don't have a lot of extra space, and a stand alone engine run stand takes up a lot of room to store. I made brackets to mount the engine on the legs of a cherry picker out of some scrap I had laying around. The brackets take up almost no room to store. I made up a panel with a couple switches, a Chrysler ecu, and a starter relay, and I had an extra set of gauges sitting around to monitor temperature and oil pressure. It works great.
Creative and efficient,great job there!
Re: Engine Run Stand [Re: rowin4] #2612458
01/26/19 10:00 AM
01/26/19 10:00 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Originally Posted By rowin4
Originally Posted By sgcuda
Originally Posted By polyspheric
How to break in an engine on a stand: you can't.
I've never seen anyone ever fire up a new engine and immediately take it out on the road to load it. You warm it up, bleed the cooling system, check temp and oil pressure, check the timing and idle, listen for noises, check for leaks. Usually takes about an hour or so. So what's the difference if I run it on my stand? If I have to tear into anything, I don't have to worry about scratching the paint on the fenders.
I used to do that. Put the engine it , hook everything up, top off the fluids and fire it up. I lived in town so I drove out to the expressway , there was 3 mile stretch to the next exit. I would do 3 blast up to about 100 and down and take the exit back to the house. Then checked everything over , never had a leak . Changed the oil and was ready for the track.
I stand corrected. 1.
But for any real budget bracket racer, all that's normally done is test run the engine, in the car, in the driveway. Yank if necessary. Race when ready.
Re: Engine Run Stand [Re: RTSrunner] #2612501
01/26/19 12:08 PM
01/26/19 12:08 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
iagree
Re: Engine Run Stand [Re: MattW] #2612513
01/26/19 12:38 PM
01/26/19 12:38 PM
Mrrandyj you are certainly willing to fab up/sell another set of em correct! EDIT on a side note here is a good article on ring breakin. www.mototuneusa.com then scroll down to & click on "breakin secrets". A motorcycle site but the principle is the same. Their take is that you get ONE chance to do a proper (ring) breakin that will properly load the rings & give "excellent" leakdown numbers as opposed to "good" leakdown numbers & that seating in over time is bogus. their take: goose it hard/repeately during breakin & seperately I am a believer in the BRM dingle berry hone for the final hone finish. BRM wants you to bore to size then flexhone & I disagree on that & feel that a "normal" bore on a grasshopper then rigid hone of the correct grit THEN a final brief dingle berry hone.
Re: Engine Run Stand [Re: kzinge1] #2612694
01/26/19 06:21 PM
01/26/19 06:21 PM
montana
BANDIT Offline
BANDIT  Offline
montana
I guess the OP should have refrained from using “break in” in his text, even tho title says “run in”. As others have said, breaking in cams, timing, valve and carb adjustments are much easier, not to mention any kind of leaks. And there is nothing sweeter than having someone spend half a day installing their engine in a car, then firing it up in a couple of cranks and having a nice smooth running engine immediately. The older I get, the less time I’d like to spend fixing something in a full bodied car, that could have been much easier on the stand. The references to break in procedures are interesting tho. Just my thoughts.
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
1980 Plymouth Arrow 572 Hemi.
242" Mullis Dragster. 6.90@ 200mph
Re: Engine Run Stand [Re: kzinge1] #2612757
01/26/19 08:53 PM
01/26/19 08:53 PM
west palm beach, florida
modelmakerinc Offline
MRRANDYJ. THAT IS BRILLIANT.
Absolutely love it. You could easily mount exhaust and mufflers.
Gotta say, I may steal that idea for my next "I wanna fab something" kinda weekend. 👍
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: Engine Run Stand [Re: 1DGEMAN] #2612769
01/26/19 09:14 PM
01/26/19 09:14 PM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
Found some old pics of it. I have since added a 5 gal fuel cell. It breaks down and stands up against the wall. I can also mount a 5.9 cummins on it.
Real Men shift for themselves
Re: Engine Run Stand [Re: kzinge1] #2612773
01/26/19 09:23 PM
01/26/19 09:23 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Here's the engine stand I slapped together quick 'n' dirty on an existing cart to check a 360 for leaks and a little tuning;
Re: Engine Run Stand [Re: modelmakerinc] #2612804
01/26/19 10:53 PM
01/26/19 10:53 PM
CT
mrrandyj Offline
mrrandyj  Offline
CT
I had exhaust hooked up when I ran it. I had an old 2 1/2" set of headpipes and mufflers that I quickly put on when needed.
Re: Engine Run Stand [Re: kzinge1] #2612818
01/26/19 11:32 PM
01/26/19 11:32 PM
montana
BANDIT Offline
BANDIT  Offline
montana
Here is a picture of mine.
Re: Engine Run Stand [Re: BANDIT] #2612819
01/26/19 11:34 PM
01/26/19 11:34 PM
montana
BANDIT Offline
BANDIT  Offline
montana
Another.
Re: Engine Run Stand [Re: kzinge1] #2613187
01/27/19 08:39 PM
01/27/19 08:39 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I'd love one of those... but it would just give another reason for some of my neighbors to hate me.
Re: Engine Run Stand [Re: BradH] #2613220
01/27/19 09:59 PM
01/27/19 09:59 PM
montana
BANDIT Offline
BANDIT  Offline
montana
I have talked to all my neighbors, most of them come to watch, pretty good people. I try not to run anything after about 7pm and not early in the am. I have slip on mufflers for some of the headers, but this set, off of my Avenger, have to big of collectors.
Re: Engine Run Stand [Re: BANDIT] #2613227
01/27/19 10:09 PM
01/27/19 10:09 PM
I'm gonna grab my chop saw/bench grinder/drill press & my scrap metal & get after it. Good pics!
Re: Engine Run Stand [Re: RapidRobert] #2613447
01/28/19 12:10 PM
01/28/19 12:10 PM
an8sec70cuda Offline
Here's my test stand. Fits BB Mopar only...all I've ever had on it. Cobbled together w/ scrap pile metal, looks rough as he11, but it works great.
Awesome for breaking in flat tappet cams and for engines that need the heads torqued again after a few heat cycles.
Used an old 4 speed bellhousing and flywheel, old radiator, a couple gauges, extra ignition box, a couple toggle switches, etc.
Very simple, very rough, but very functional.
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
Re: Engine Run Stand [Re: mrrandyj] #2613478
01/28/19 01:24 PM
01/28/19 01:24 PM
Portland, OR
shawge Offline
shawge  Offline
Portland, OR
Nice job! Simple and effective.
