69 b body rally dash amp gauge #2608041
01/17/19 01:26 PM
01/17/19 01:26 PM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
anyone who have had the amp gauge converted to volts if so by who,and your thoughts on whether or not you should even bother about doing it,thoughts and opinions negative or positive welcome. thanks
Re: 69 b body rally dash amp gauge [Re: moparpro] #2608096
01/17/19 03:17 PM
01/17/19 03:17 PM
No conversion exp but I like my ammeter (do the Nacho bulkhead parallel bypass) & I add a voltmeter to switched 12V
Re: 69 b body rally dash amp gauge [Re: moparpro] #2608199
01/17/19 06:29 PM
01/17/19 06:29 PM
Berwyn, IL
challenger70 Offline
Berwyn, IL
I did mine through Redline Guage Works. I also did it on my ebody when they restored those guages. I like it, but I am running a 160 amp MSD 1 wire alternator.
Re: 69 b body rally dash amp gauge [Re: moparpro] #2612122
01/25/19 04:22 PM
01/25/19 04:22 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
Someone modded a volt gauge to fit, and look, like a factory volt meter over here:
DIY voltmeter mod for 2nd gen Chargers
Re: 69 b body rally dash amp gauge [Re: RapidRobert] #2612185
01/25/19 06:40 PM
01/25/19 06:40 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
and alt upgrade. Without the alt upgrade, the ammeter will be still sensitive to fail. The bulkhead parallel path or bypass just save the overheating there wink
